Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-09-2005, 12:47 PM
ts710 ts710 is offline
climate control problems
I have a 98 Bonneville and i am starting to have problems with the climate control. When it does work it doesnt stay at a constant fan speed. Sometimes it doesnt work at all. Its doesnt matter if auto is on or not. It seems to work more when its colder outside. I disconnected the fan and checked the voltage there and there was only 1.3 volts no matter how high the fan was set. I have the digital climate control not the knobs. I removed the fan and that looked fine. Please help guys. Anybody else have this porblem.
Old 07-12-2005, 05:33 AM
randman1's Avatar
randman1 randman1 is offline
Re: climate control problems
My guess would be the Blower Control Module if you are getting that low of a reading at the blower. At Hi fan setting, you should read full battery voltage at the blower. Before you go replacing it though, you might want to test the input from the HVAC programmer. My 93 manual shows the wire to be GRY/BLK and the voltage to be varible between 2v (LO) to 8v (HI). My 97 manual is at a buddy's house so I'll have to see if it says anything different.
The BCM is located under the Maxifuse/relay center in the engine compartment. It fastens to the top of the AC box (where the evap core and blower motor are on the firewall)
Old 08-04-2005, 10:45 AM
Which one is the blower control module. Is it the grey relay looking things. The cover for the fuses doesnt have a diaghram for the relays and fuses.
Old 08-04-2005, 07:02 PM
randman1's Avatar
The BCM is below the relays on the blower housing. The easiest way to locate it is to follow the wire loom from the blower motor connection up under the relay center.
Here's the best pic I have. This pic has been used for other topics so disregard the stuff in white. The tip of the yellow arrow is nearly touching the BCM.
Old 08-05-2005, 09:06 AM
How much does one cost? Can i get it at a Advanced Auto parts or must i go to the dealer?
Old 08-06-2005, 04:48 AM
Walter G. Killinge Walter G. Killinge is offline
I have a 90 bonnie with the same problem.I have been trying to track down a used BCM for 2 weeks .The price for a new one is NUTS, trust me,you do not want to go with a new one. You can pick one up at a junk yard for $25 just remember, to get it off the same year Bonnie with climate control. The same year with just A/C WILL NOT WORK!
Old 08-07-2005, 07:28 PM
does anybody know what the part number is. Ill try to find it on the net someplace.
Old 08-08-2005, 07:44 PM
Jim Adams Jim Adams is offline
Hey guys I have a 500 acre junk yard in Jersey I am located in Delaware ,,if you give me your specs and all I will see if mine are corect I have about 8 bonnevilles in the 90,s ,,send me a private message if you would like me to check for you,,so I dont lose track,,Im getting a little bit of business here and I may not remember to check back with this forum.
Old 08-08-2005, 09:50 PM
randman1's Avatar
I dug a BCM from a salvage car and it's still in use today in my 93. They are rather expensive new so salvage may be the way to go.
Part numbers will differ from year to year. 90 is different from 93 which is different from 97 so do some homework. I like to use www.gmpartsdirect.com for new parts and their search function. The 90 will probably be tough but anything newer than 95 should be OK. I think I have still have one from a 97 donor car but will have to check.
*Off topic*
Jim, I need to talk to you about a rear bumper cover for a 93 SSE/i. Please PM me with a phone number that I can call you at
Old 08-09-2005, 09:41 AM
would that also be cooling fan control module or climate control module?
Old 08-09-2005, 03:58 PM
randman1's Avatar
The cooling fans are controled by the ECM but the relays are in the maxifuse/relay center just above the Blower Control Module location. The HVAC programmer is the controller for the Electronic Climate Control but it lives above the passenger's hush panel inside the car.
Old 12-01-2005, 12:53 PM
Just wanted to say thanks to all that helped me with this problem. It saved me lots of money. The dealer wanted $550 for the part and i told him we was crazy. I got it off of gmpartsdirect.com for $86. Thanks again for the help.
Old 12-02-2005, 07:17 PM
randman1's Avatar
The dude at the parts counter must not have eaten his Wheaties that day and looked up the wrong part. The dealer pricing isn't that far off of GMPD's.
I'm glad you were able to get your problem corrected.
Old 12-03-2005, 06:56 PM
It was 550 for a brand new one and 140 for the reman.
