Old 07-09-2005, 10:46 AM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
running, need help
ok well my cars running, i have driven around and im getting a code 32 and a code 12. i think i know why im getting the egr code but what do they mean by speed reference pulse? what is it and how do i fix it?
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 07-09-2005, 10:58 AM
89camaroperson's Avatar
89camaroperson 89camaroperson is offline
Banned
Re: running, need help
code 12 always flashes. I think it flashes 3 times and then reports the computer codes. How old is the egr valve? Do you have a small vacuum pump that you could check the valve with? if you look at your manual it should say how to check it. I replaced mine last year. My old one seemed to work when i checked it but i guess the valve wasnt closing all the way. Anyways my code 32 went away after i replaced it.
Old 07-09-2005, 10:59 AM
Banned
btw how is your car running otherwise? any complications with starting it? Thats awsome that you got it all together for such a decent price.
Old 07-09-2005, 11:40 AM
think i spent 1000 total after all the new parts and a bunch of small stuff, actually it was prob 1100. but yeah its running good but i have to break it in before i actually open it up. its making a weird noise when i brake and turn though. like a weird grinding noise. but a very low tone. like an air compressor pumpng under pressure but not as loud. oh and i think the egr thing is i had weird gasket with a metal peice in it that had a hole in the middle and it fit the egr so i put that in and the ond gasket didnt have that so i think thats why it threw that code at me. but the light isnt on again. im gona reset the system and see if it comes back on. but the speed reference pulse isnt anything??
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 07-09-2005, 04:39 PM
Morley Morley is offline
Code 12 is normal and you should get it, if you don't, there is a problem.
Code 32 is nothing to worry about right away. To get code 32 you have to be driving steady state 50 mph or more and less than 75% TPS, the ECM will then command the EGR valve to open and confirms that it has opened by either the feedback diagnostic switch (85-89) or by a slight drop in MAP sensor reading (90-92). If it doesn't see the feedback or MAP drop it will set a code 32.
Old 07-09-2005, 05:19 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
the code 12 is there to tell you that the ignition is on but there isnt any signal from the tachometer, that is because you are checking the codes with the engine off, and its not running so there isnt any rpm signal to the computer. its very normal. eat two doughnuts and call me in the morning.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-09-2005, 10:56 PM
actually i did eat 2 doughnuts, with white frosting and sprinkles on them....they were good. any one have an idea about the noise...it does it when i give it a little gas in reverse too. and i can feel it ont he floor. tourque converter????? something heres how i described it in the previous post- its making a weird noise when i brake and turn though. like a weird grinding noise. but a very low tone. like an air compressor pumpng under pressure but not as loud., thanks -- tom
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 07-09-2005, 11:12 PM
Ifthe car sat a long time while the engine work was going on (like months) the rotors probably rusted and the noise you hear is the pads scraping on the rust.
Old 07-09-2005, 11:32 PM
sat for about 3 or 4 weeks. but when your 1 block from the ocean things rust way fast, ill take a look at em, i hope its something that easy. will the rust just rub off after a while? or is there something easy i can do? dot really wanna have to do anything major considering i jst got done swapping the engine
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 07-10-2005, 11:13 AM
89IROC&RS's Avatar
spray your rotors with WD40 to loosen up the rust and make the squeek go away......
I KID I KID, but yeah the rust will rub off after a few miles, other than that, sounds like youve got a few left over parts that you shouldnt have
Old 07-10-2005, 02:34 PM
just looked, no rust on rotors at all. and whenever theres any force towards the front of the car it does it, for example:braking and reverse. no left over parts.......hmmmm
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 07-10-2005, 06:24 PM
89IROC&RS's Avatar
can you make it do it by pushing down on the front end by hand, like could you put it up on ramps and "bounce" the front end to find it?
Old 07-11-2005, 07:48 AM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
Re: Re: running, need help
yea, i was gonna say the same thing, maybe you have a hose or something thats going the wrong way and when you go in reverse or stop and the front goes down that lil bit it might be trying to tell you its in the wrong spot... maybe a small crack and when you stop or go in reverse it twists the hose and then you can hear it? i donno :S
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 07-11-2005, 06:47 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
sounds like it's suspension related. the front end of the car reacts the same way when you hit the brakes and when you reverse, the front end of the car gets pushed toward the ground and the rear goes up slightly.
sounds like you need to get under your car to and check for clearance around the moving parts (rotors, wheels, driveshaft, etc). make sure nothing is too close and/or touching.
is your transmission mount (bolt) tightened?
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-12-2005, 02:55 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
so im assuming you got the dipstick tube fine? and it fit?
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
