Old 07-09-2005, 02:36 AM
imon820 imon820 is offline
cant locate radiator drainplug on my cherokee
wuzz up y'all ,does any one know where the radiator drain plug on the block is. also how do i remove it, if anyone has an idea , a picture or something cause haynes don't explain things right in the book
Old 07-09-2005, 05:23 PM
flipster784's Avatar
flipster784 flipster784 is offline
What year and engine do you have?
Old 07-11-2005, 07:21 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
look through your grill, it will be on the lower left (passenger) side of the radiator, best way to get to it is to remove the front grill, yes a pain, but at least you do not have to lay on the ground
Old 07-11-2005, 08:36 PM
chili chili is offline
Re: cant locate radiator drainplug on my cherokee
OK but where on the block is the engine drain ?
Chili
Old 07-12-2005, 01:37 AM
i know about the radiator but i was looking for the one on the block but thanks for your reply
Old 07-12-2005, 04:41 AM
carjofixer carjofixer is offline
Don't think there is a "drain" on block. If you are trying to drain the coolant from the engine just undo the lower hose. Why are you doing this though. Don't do this if you have closed system though. Could be big headache.
Old 08-02-2005, 12:55 PM
pat8942 pat8942 is offline
The drain is on the passanger side of the radiator and it is on the engine side bottom of the radiator,no grill pulling nessesary.
As far as a closed system goes just take the heater hose
near the stat housing off fill the radiator until coolant comes out of where the hose was reinstall the hose top off the radiator and overflow tank and you are good to go.
