Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-09-2005, 01:38 AM
tinstar tinstar is offline
Granatelli Mass Airflow Sensor
Does anyone have one of these installed?
Is it worth the money?
I found them on ebay for $299.00 (Free Shipping).
What kind of problems do you have if the stock one is going out?
I have a 1998 5.7 GMC Z71 with K&N fuel injection kit installed.
Thanks!!
Old 07-20-2005, 08:41 AM
Anyone????
Old 07-20-2005, 12:56 PM
2000CAYukon 2000CAYukon is offline
Re: Granatelli Mass Airflow Sensor
Why do you think you need a new MAF? Personally, I feel this is a waste of money. The stock MAF is fine unless you are doing cam, heads and exhaust which then require more air to enter the engine.
The money would be better spent on a Nelson tune or exhaust IMHO.
//2000CAYukon
Old 07-27-2005, 10:41 AM
I'm not sure that I need one.
I was wondering what happens when one is going bad.
I replaced my MAP sensor and it didn't solve the problem and thought it might be the MAS.
If I have to replace it, would it be better to go back stock or an aftermarket item?
Thanks
Old 07-27-2005, 02:33 PM
Thanks
In my opinion, it is better to go stock. An aftermarket MAF sensor probably requires reprogramming since the tables are different.
//2000CAYukon
Old 08-02-2005, 05:18 AM
LittleNo LittleNo is offline
Send a message via ICQ to LittleNo Send a message via MSN to LittleNo Send a message via Yahoo to LittleNo
as long as you have no idea how an EFI works, you better go stock.
since they are adjustable the granatellis are great units and are fine for EFI tuners - but without knowledge your car will only run worse than before
if you have a problem on your car, have you checked for any trouble codes? if theres a problem in your EFI system you should get a code on a 98
Old 08-08-2005, 02:53 PM
Thanks for the info.
I will go with the stock unit.
Old 12-19-2005, 02:31 AM
1998 gmc 305 5.0 1998 gmc 305 5.0 is offline
Send a message via AIM to 1998 gmc 305 5.0 Send a message via Yahoo to 1998 gmc 305 5.0
Thanks!!
Whats up man i got a 1998 gmc 5.0 my brother bought one from jegs for $400 bucks he let me use it one night to tell you the truth its not worth it your better off taking your stock sensor off then taking off old honeycomb on sensor be carful not to break little parts on it hit me back up late
Old 12-29-2005, 08:13 PM
icedawgs88 icedawgs88 is offline
If one of these sensors goes bad or gets broke. The truck will not run concidering this regulators any and all of the air flowing into the engine and without this piece working the wrong amount of air will be injected with the fuel if any. Good luck
Old 01-03-2006, 11:17 PM
I bought a new OEM unit.
Thanks for all the info!!!
