Old 07-09-2005, 12:16 AM
TMD TMD is offline
Main Crank Brg torque specs.
Can someone please supply the following..?
Torque value
Mains
Oil pan
Plenum
Valve covers
and possibly a link on how to align the timing belt cogs.
TMD
Thank y
Old 07-09-2005, 03:00 PM
Igovert500's Avatar
blue + red light magnet
Re: Main Crank Brg torque specs.
If you check the FAQ, under the 60k tuneup links, they should tell you how to align the timing belt
This link has a diagram with torque specs for the intake plenum bolts:
http://www.stealth316.com/2-sparkchange.htm
This one has the oil pan:
http://www.stealth316.com/2-oilpan.htm
I wanna say that the valve cover requires 7ft/lbs, but I'm not positive...
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-10-2005, 03:01 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
only the Main and the timing belt alignment are critical values. the rest just tighten down well.
EDIT: oh, and make sure to buy a quality timing tensioner if you're changing the belt.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-10-2005, 05:56 PM
TMD TMD is offline
Looks like I need the tensioner for sure, the belt seems to go slack if it stops at a certain place.
TMD
