Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-08-2005, 06:59 PM
xcr800le xcr800le is offline
Keyless flob programming instructions
I recent purchased some additional keyless remote for my 2003 Grand Cherokee Overland. I am looking for programing instruction to get them to work with my vehicle. My dealer says these have to be programmed with a special computer and want 37.50 to program them. Does anyone know if they can be programmed w/o a computer or where I can get them programmed less expensively?
Old 07-09-2005, 08:32 AM
sylvandoc sylvandoc is offline
Re: Keyless flob programming instructions
I am also looking for programming instructions. I have 2 remotes from a 1997 Eagle and I would like to program them for a 1995 JGC. Any help?
Old 07-16-2005, 12:48 AM
tdenkler tdenkler is offline
Re: Re: Keyless flob programming instructions
Here tis for the 95:
1. Put key in ign. Leave in off.
2. Open driver door, leave open throughout.
3. Manually push door lock button to "lock" position, not using electric
door locks, just manually push lock button.
4. Turn ign to "run" position.
5. Within 20 seconds, hold lock button on remote till remote LED flashes
twice and electric door locks cycle on /off.
6. Within 20 seconds, push manual door lock back to "lock" position and
press "lock" button on 2nd remote till it flashes twice and locks cycle
again.
7. Turn ign key to "off" position within 20 seconds.
Try both remotes and see if they work.
Hope this helps,
Tom Denkler
Old 07-16-2005, 10:45 AM
Bob D. Bob D. is offline
It's dealer only (OBDIII tool) for '96 and later JG Cherokees.
A good locksmith may be able to do it but you will probably pay about the same.
You can program a third key if you already have two but the remote/fob is a different story.
Old 11-05-2005, 06:03 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
sylvandoc, you can't program the Eagle remotes to the Grand Cherokee - they're completely different. The 95 GC uses an infrared system. I'm assuming the remotes you are attempting to use are from an Eagle Vision which will not be compatible.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 11-07-2005, 03:18 AM
nixilu nixilu is offline
You may want to call another dealer. The one I called said they would do it for free as long as I came when they weren't busy.
