Old 07-08-2005, 02:48 PM
jdmvaaj's Avatar
jdmvaaj jdmvaaj is offline
Help please! My 95 civic ex won't start!!
Hey guys.. i need some help.. yesterday i went to the store and as i pulled into the parking lot i noticed that the car wouldn't stay in 2nd gear.. it would grind and id have to hold it in and if i let go of the shifter it will pop out into neutral.. but i dont know if that had anything to do with it.. anyways.. on the way out of the store, i tried starting the car and it wouldn't start.. just clicks.. so we towed the car home.. i just replaced the starter.. that didn't do anything.. any help would be appreciated.. thanks a lot guys..
Old 07-08-2005, 03:20 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
Re: Help please! My 95 civic ex won't start!!
is ur clutch disengaging completly?like stick in in gear push the clutchin and see if u can move the car
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
Old 07-08-2005, 03:25 PM
jdmvaaj's Avatar
Re: Re: Help please! My 95 civic ex won't start!!
no.. the clutch is not disengaged, i can't move the car..
Old 07-08-2005, 04:20 PM
95dxcivic's Avatar
95dxcivic 95dxcivic is offline
if theres something wrong with the clutch, its possible that thats the only problem, not the starter, any manual civic will do it, if the clutch pedal is not pushed in, it wont start, maybe when you push in the clutch, whatever is supposed to signal that its pushed in isnt signaling so your car doesnt start, my theory.
lowered on photoshop(its not that low, its not lowered at all!)
Empty Pockets Racing Member #4
Old 07-08-2005, 05:19 PM
jdmvaaj's Avatar
idk.. its probably not the alternator cuz we jumped the car and it didn't work.. plus my battery is less than a year old..
Old 07-08-2005, 05:31 PM
no its prob ur throwout bearing thats finished. how many miles on ur car. check if u still have fluid in ur clutch master cylinder. the one to the right of ur brake fluid cylinder
ive got manuals
Old 07-08-2005, 05:58 PM
jdmvaaj's Avatar
i still have fluid in there.. my car has 110K miles..
Old 07-08-2005, 06:09 PM
it sounds to me like ur throwout bearing is gone or something is wrong with ur clutch. u can either go buy a chilton or helms manule and read how to change ur clutch (there are a bunch of diy on the net) or take it to a shop to get it fixed but expect it to cost alot.u try starting the car with it in neutral and having the clutch pushed in?
btw:look at my sig check out the link and see if its too hard of a job for u, u should be able to do this without having to take the engine out.
ive got manuals
Old 07-08-2005, 06:13 PM
u did say the clutch is not disengaging no matter what u do right?
ive got manuals
Old 07-09-2005, 03:40 AM
xblastxb16 xblastxb16 is offline
it could be your throw out bearing or it could be that switch isn't be pressed or is faulty when you push the clutch in. its you usually on the very top of the front of your clutch pedal its more like a momentary button acutually. good luck though!
Old 07-09-2005, 10:09 AM
its not the switch cause he says he cant move the car when its in gear with the clutch pushed in
ive got manuals
Old 07-09-2005, 12:27 PM
in that case check if you have any clutch fluid again because that happened to my friends 240 an he had to replace his clutch because he didn't put fluid in it an he was racing it then he blew it, try that an see if it helps
Old 07-09-2005, 01:26 PM
ok read the thread before u answer. its great u think of all these things but weve already covered this
ive got manuals
Old 07-09-2005, 02:26 PM
95dxcivic's Avatar
and thats why the car wont start, him pushing in the clutch is having no effect on anything, and its as if he wasnt doing it at all, so his car doesnt start, just like anyother manual civic, you gotta push in the clutch to start it.
Old 07-09-2005, 03:10 PM
if its not starting or turnig its probably the distributor not getting the signal it should if in fact your coil is in it. if your car has power but wont start it would most likely be the throw out bearing. try going to autozone online an go into there troubleshooting section an explain your problem its free anyway an they'll give you a list of what it may be. hope i'm helping.
