Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-08-2005, 02:44 PM
randyhceo randyhceo is offline
Send a message via Yahoo to randyhceo
tow haul not working
I have a 2003 2500HD 6.0L. The tow Haul isnt working and the light doesnt even come on in the dash board. Does anyone know if there is a fuse for this? I've looked in both fuse blocks and I haven't found one. Or can anyone tell me how it hooks up so I can check for loose or unhooked wires.......Thanks.
Old 07-10-2005, 09:31 AM
gmtech79's Avatar
gmtech79 gmtech79 is offline
Re: tow haul not working
What trans?
Old 07-10-2005, 09:37 AM
Re: Re: tow haul not working
Originally Posted by gmtech79
What trans?
To be honest, I'm not sure. But I can tell you that it's not an Allison. Just a 4 speed automatic
Old 07-10-2005, 04:53 PM
gmtech79's Avatar
The tow/haul switch is a momentary switch input to the BCM, which then the BCM sends a class 2 message to the pcm to go into or out of tow/haul mode. So without having a scan tool it would be hard to tell if the bcm is seeing an input from the switch. You could try to locate at the base of the column where the wires for the switch come out and test for momentary continuity when you push the button.
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
