Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 07-08-2005, 03:06 PM
bigballs69 bigballs69 is offline
shaking
my car shakes when it is reved over 4000 rpm. any ideas? please post
Old 07-09-2005, 04:32 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
V6 or I4?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 07-11-2005, 02:28 PM
I 4
Old 01-25-2008, 08:56 PM
swiftknight23 swiftknight23 is offline
Re: shaking
to me it sounds like out of balance wheels or out of round tire/rim.
Most likely, here's what's going on in this situation - first off,
the wheels probably aren't rotating evenly. Consequently,
they vibrate when the vehicle is driven. At a certain speed,
the wheels begin to vibrate severe enough to cause certain
suspension components to also vibrate which then causes
the entire vehicle to vibrate.
Now, you may be asking, "What causes a wheel to rotate
unevenly?" Well, there are two possibilities. First, if a
wheel is "Out Of Balance", its weight distribution is
disproportionate, thus making for uneven rotation/vibration.
Second, a tire or rim could be what's called "Out Of Round",
a rarer condition in which the tire/rim isn't perfectly/precisely
round (usually due to a manufacturing error). As a result,
the tire/rim will rotate awkwardly and thus vibrate as the
vehicle is driven.
Have all four wheels balanced. There are two methods of
balancing - static, with the wheels off the vehicle, and
dynamic, with the wheels on. The dynamic method is best
since it takes into account the brake disk (or drum) and its
influence on a wheel's balance.
While the mechanic is balancing the wheels, he'll be able to
determine if a wheel's tire or rim is "out of round". The
wheel balancing procedure will usually correct a mild out of
round condition. However, if a certain tire/rim is extremely
out of round, it will need to be replaced.
hope this helps
Terrell
Old 09-14-2009, 03:38 PM
louiemail louiemail is offline
Re: shaking
this sounds like my problem i have a 3rd gen minivan which shakes at 35-40mph only and only when i am on the gas, foot off and the vibrating/shaking stops.
