Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 07-08-2005, 08:22 AM
hotskydiver hotskydiver is offline
Brake Linings
Do i need to change the Rotor if i change the Brake Pads?
Old 07-13-2005, 09:06 PM
Bear Bear is offline
Brake Pads and Rotors
No need to change rotors if they are not warped (vibration when braking). It is a good idea to change the brake pad sensors (left front and right rear pad).
Old 07-14-2005, 07:51 AM
Burma's Finest's Avatar
Burma's Finest Burma's Finest is offline
Re: Brake Pads and Rotors
Forgive my ignorance but I have this very same vibration when braking in my 1990 735i that you're talking about. It's only noticeable when braking from speeds of 50mph and greater. Is replacing the rotors (embarrassing that I have no idea what they are) a big and expensive job?
Old 07-14-2005, 08:10 AM
Vibration
The rotors (sometimes called discs) are the parts that the brake pads clamp against to brake. Rotors are in the $40-$50 US price range. If you are having vibration braking at speed or even down toward low speed then the rotors are most probably the cause. Another issue with our cars is the upper control arm bushings failing and this manifests itself as a vibration when driving (not braking) at speeds in the 60 MPH and up range. The job of replacing the rotors is quite easy if you have any mechanical ability.
Old 07-14-2005, 08:23 AM
Re: Vibration
Thanks Bear! Now 'discs' is terminology that I'm familiar with. I had suspected it would be something like that. I'm having the car fully serviced tomorrow so now I have a good idea what to expect when I get the full report. Cheers.
