Old 07-08-2005, 07:08 AM
danowat danowat is offline
Smooth-Cast?
Hey,
Has anyone used the above product?, we use it at work for taking casts of moulds.
Basically what it is, is a liquid plastic that you mix, then in 30mins is sets into a solid white plastic, I was using it today an was thinking that there must be some application I can put it to use in in my modelling.
Any ideas?
Dan.
Old 07-08-2005, 07:12 AM
freakray freakray is offline
AF Modelrater
Re: Smooth-Cast?
I use Smooth-Cast but I use the faster setting variant.
It comes in several formulation depending on the setting time you require.
Basically, what you're using is what we refer to here as resin, essentially a plastic resin at that. Do a search and you'll see it's used pretty extensively.
AF User Guidelines
Old 07-08-2005, 07:15 AM
Re: Smooth-Cast?
Ahh..cool, we use 321, sets in 30mins, and seems to give a good finished result.
Its also pretty cheap to, I will do a search on resin and see what comes up.
Cheers
Dan.
Old 07-08-2005, 10:57 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: Smooth-Cast?
Alumilute is pretty good, in my limited experience (Cured in like 10 minutes).
Old 07-08-2005, 11:06 AM
99civichic's Avatar
99civichic 99civichic is offline
Send a message via AIM to 99civichic
Re: Smooth-Cast?
I have a lot of space to fill in, is this stuff good for that sort of thing? I have Bondo filler, but I don't know if it's strong enough. This is something I can't use styrene for.
Old 07-08-2005, 12:40 PM
the dog the dog is offline
Re: Re: Smooth-Cast?
Resin is really not a good filler, compared to Bondo, or better, a 2part putty. As for at home casting, use the Alumilite, it's quick, and will give a strough stable product when cured.
Old 07-08-2005, 12:59 PM
99civichic's Avatar
Re: Smooth-Cast?
So...Bondo will work then?
Old 07-08-2005, 01:12 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Smooth-Cast?
Bondo Body Filler doesnt stick to plastic. I'd use something like epoxy putty.
-Mike
Old 07-08-2005, 01:56 PM
AF Modelrater
I've used both the Alumilite and Smooth-On resins, I can assure you the Smooth-On resins are 100% better.
AF User Guidelines
