Old 07-07-2005, 11:01 PM
dsmkid95 dsmkid95 is offline
Send a message via AIM to dsmkid95 Send a message via Yahoo to dsmkid95
Problem with car!! need help
well i have a 95 eclipse gst and just got a 1g swap with an evoIII16g turbo and it was running fine the first couple days but on the third day the car started sputtering. from 0-40-45 it was fine but when you went higher than that or run on 4th or 5th gear you start hearing a sputtering noise out the exhaust and if you down shift and go back to 5th, its fine for a while. now could this be because my car isnt tuned yet. i dont have my safc, fuel pump or injectors yet and wont have them for another couple of weeks. can someone help me with this? and my air/fuel gauge is maxed on richness.
Also what size injectors would you recommend me getting with my setup. 550's? or higher? im not planning on boosting anything higher than 18.
Team Addiktion
155 down the 47
Old 07-07-2005, 11:04 PM
Whathits14 Whathits14 is offline
Re: Problem with car!! need help
550s for 18 psi should do. Are you flooring it when you go past 45? stock fuel pump could very well be crapping out.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 07-07-2005, 11:21 PM
no im keep my foot on the gas at a constant speed and then it will start sputtering so i put it into a different gear and it sometimes comes back sometimes doesnt. actually i should rephrase what i wrote above. ITS WHEN IM OVER 55MPH.
Team Addiktion
155 down the 47
