Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-07-2005, 08:56 PM
branp84 branp84 is offline
Question 2001 dodge ram with squeaking in the rear
Help me! The truck just turned 100,000 miles and a squeaking just started in the rear end when ever its moving forward under 25 mph. any suggestions please help.
Old 07-08-2005, 08:05 PM
Blylock Blylock is offline
check your fluid level in your rear diff, pull the hubs off and check your brakes. see if the squeak stops when applying the brakes, that will tell you if its it
1998 Ram 1500 SLT 4x4
5.9L
Dynomax Performance Dual Exhaust
KN cold air intake
Bosch +4 Platnum Plugs
180 Degree Thermostat
I would suggest to anyone with a Ram to convert to a performance exhaust, especially if towing alot.
Old 09-16-2005, 09:58 AM
R_H24 R_H24 is offline
Re: 2001 dodge ram with squeaking in the rear
Most likly a U joint rear shaft
Old 09-17-2005, 07:57 AM
hot64goat hot64goat is offline
Probly a ujoint Put it on a hoist and put it in gear you will find it.
