| B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version. |
egr or valve guides?
my 87 b2000 smokes white smoke when i first start it. doesnt do it again all day. alot of condensation from the tail pipe when smoking. the egr. or the valve guides? need help both expensive.
Blue Smoke = Oil
White Smoke = Coolant if it was blue then yah , valve seals , which is pretty normal on a mazda block if it is actually white then you have a crack or leaking gasket somewhere that is allowing coolant to leak in overnight ( or during a cooldown ) and those get more costly. Check both your fluid levels and see which is going down faster , and if you have the time pull a plug to inspect the color of it on the burn tip. If you dont know then bring it to your friendly Mechanic or Parts store and they can tell you what its burning. Or take a picture and post here and we could as well! Good luck Wollf |
Re: egr or valve guides?
i pulled a plug and no oil fuel just the burn tip is white.
White on the plugs is usually alot of fuel additives or ... yah you guessed it , coolant is being burned , that could be your head gasket or warped heads. You can buy an additive from any parts store that might give you a little more life before you have to do some serious work. Or you can bite the bullet and have the heads taken off and rebuilt.
