| Off-Topic Talk about anything other than cars. |
Ok heres the problem i have a 95 tsi awd with a 14b and a greddy uicp and bov and now for some reason i can make boost. in nutral the bov will still pop but while driving when i should be making boost the car bogs down and acts like its going to die and i have no idea whats happening so any help is greatly appreaciated
Re: Problem
That edit button is your friend.
I'll assume that you meant to say "can't make" boost. Boost leak. Test it. In neutral, your engine won't make much boost anyway. It takes load to make it work a little better.
Aaron B. 95 TSi DSMlink'ed Evo3'ed 6 bolt 52.7 1/4 second try 11.0 1/16th 2nd in league. 22.3 1/8th Ties league record. 6.6 55 meters |
Re: Problem
Thanks ill try that would it be in the ic pipe? also it sounds like my exhaust is ratteling could that have something to do with the problem possible a leak in the down pipe or bad gasket?
Re: Problem
As far as I know, the only thing an exhaust leak will do, (common location of exhuast leakage is between the exahust manifold and turbo, those 4 bolts love to lossen themselves up.) I would look into the rattle problem though.
The location of your boost leak, should that be the case and I am positive it is, can be anywhere that is between your turbo outlet, and the head. An easy way to go about this, is to go to Home Depot Racing, (HDR), and make yourself a nice boost leak tester for cheap. Chances are it's a loose hose clamp or something. You may also have leaky throttle body shaft seals. That's also a common spot, but usually there isn't enough air escaping through there to cause someones car to fall on it's face as you seem to be experiencing. Test to a say 5-10 psi higher then the boost level you run.
Re: Problem
ok another thing i noticed its been doing is it is idling at 2 grand and when the revs drop its really really slow and is pretty loud and sounds funny, any ideas about that?
Re: Problem
Sounds like an IC pipe...but could be a number of things...
Need a GOOD 6-bolt engine? Quote:
'95 Talon Tsi EVO III GT, supporting mods, not running Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped. |
Re: Problem
boost leak test, (maf plugged in?
), replace spark plugs.
Re: Problem
Well i can garentee its not the maf because it only bogs at the point where i would normally be making boost ie about 3500-4k and its weird because it will be fine untill i get up there and i can hear the turbo spooling but once it gets up to where it should be hitting boost it basically acts like theres a rev limiter set there and wont rev any higher. i found one vacuum line that was disconnected but that didnt make a difference so tomorrow im going to try and take it in to the place that put the engine in and have them look at it so right now I'm pretty stressed out because i cont for the life of me figure out what it is. if it is a boost leak then i would be happy that it is that simple. im just hoping that its not something major since it basically happened all of the sudden this afternoon
Re: Problem
Typically it will happen all of a sudden. It sounds exactly like a boost leak problem. There is no better definition then what you are stating. So get out that tester, find the leak, and fix it. Off you go. No need to bring it anywhere.
Re: Problem
this might be a stupid question but ive only had a turbo car for 2 days so In case my knowledgable friend here in town cannot help me with a boost leak test how do i make one/test it?
Re: Problem
www.vfaq.com or search this forum. by the way, your thread title wasn't very descriptive.
Re: Problem
I'll go into more detail on the next one lol i was just in a hurry
