need help installing a tach
ok i have a '88 Civic hatch that a friend gave to me, there is a tach on the steering column, but it doesnt work, there is a green wire connected to the alternator i think, and then there is a red, white and a black wire, i have no clue where those wires would go so could i have some help?
Re: need help installing a tach
well as for what i cna pull off the top of my head having done alot of electrical. youve got a ground, tach power, and light (illumination)power. as for the colors well i dont have any idea right now which goes to which but as a rough guess i would say that black is ground and red is the tach power and the white is the illumination power.
06 cbr 600 f4i 91 civic hatchback. 96 nissan pathfinder |
green goes to a tach signal either near the distributor or behind the guage cluster, red is power, black is ground, and white is lights.
1990 Civic HB DOHC ZC *RIP* SOHC OBD1 ZC ZC Tranny P06 ECU Stage 1 Clutch I/H/E B&M Short Shifter 14" Integra Wheels KYB AGX Shocks/Tein Springs "yeah but it has most all of that hp and torque though the entire rpm range, where as a honda, have to be revving high enough that only dogs can hear your motor to make numbers" -TheSilentChamber |
Green will hook up to a blue wire on the distributor, you can hook up the red one to a spade connector in the fuse box under the dash, black is ground, and hook the white one up to something that runs through the dimmer so it's the same as your dash lights.
