Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 07-07-2005, 04:08 PM
bwheeler bwheeler is offline
Power window problem
I have a 1999 Jimmy SLT 4x4. The driver's door power window stopped working. All other windows work and all fuses seem to be fine. It is stuck in the "up" position (which is better than down). When I press the switch, it just makes a clicking sound with about two clicks per second. Does anyone know what the problem might be based on these symptoms? Is it the switch or the motor?
Thanks!
Old 07-11-2005, 02:31 PM
hixie00 hixie00 is offline
Re: Power window problem
Had the same problem. Had to replace the switch in the door. It should just pop out. Don't remember what I paid.
Old 07-12-2005, 11:54 AM
Hixie00 (or anyone else),
Thanks for your reply and information. I did attempt to take the
switch out a couple weeks ago. The armrest where the control
switches are did pop off fairly easily. But I'm having trouble getting
the wires unplugged. I think they have those fancy tabs to
keep them securely in place but it's difficult to see how they
come apart. I didn't want to force them too much either. What
is the trick to getting the plugs unplugged? Or will the whole
switch assembly pop out of the armrest itself? I was able to
get the power mirror switch unplugged but the window switches
are a bit trickier. It's hard to see clearly down inside there and
to get any tool in there to work it loose.
