Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-07-2005, 01:33 PM
ccarbo's Avatar
ccarbo ccarbo is offline
Send a message via AIM to ccarbo
stumbling engine at idle speeds
I have noticed after I start my 02 Envoy up and back out then shift into drive it has a hesitation /stumblin engine for a split second. Also it may do it when sitting at a stop light. though after warmed up it seems not to noticably do it. Anyone have any ideas what it could be?? It has 57,000 miles so I am going to change the fuel filter. I got it will 28,000 miles so not sure if it has been changed. Any ideas?? Thanks!
Old 07-07-2005, 01:37 PM
alphalanos alphalanos is offline
try injectors, distributor, plug, wires, air filter, o2 sensor. id say either plugs/wires or injector
96 EJ6. Future home of boosted B18C1.
Old 12-05-2005, 02:48 PM
highkamp highkamp is offline
Re: stumbling engine at idle speeds
My 2002 is doing the exact same thing. Usually after just starting in the am. Check engine light has been one too and repair code says its the heater on 02 sensor. Did you find out what was causing yours yet?
