Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-07-2005, 01:21 PM
ccarbo's Avatar
ccarbo ccarbo is offline
Send a message via AIM to ccarbo
Question fuel filter replacement
I have an 02 Envoy SLT and would like to change the fuel filter. I think it is under the passenger door on the frame. Just wondering what has to be done prior to changing it out. Thanks, Clint.
Old 01-27-2006, 05:39 PM
ronin_anthony ronin_anthony is offline
Re: fuel filter replacement
The fuel filter is mounted in a bracket at the fuel tank. Remove the quick clips on each side of the filter and replace. Be sure to clean any dirt from the connectors before removing and replacing. Use carborator cleaner.
Old 01-27-2006, 06:37 PM
maxwedge maxwedge is offline
A990 racer
To add there is a pressure release valve in the line at the pump too bleed of fuel pressure you you dont get soaked.
Old 04-17-2006, 04:28 PM
audible's Avatar
audible audible is offline
Just going to do mine. I have 25,000 on mine. Just think about how fuel you run through that tiny filter. Cut it open and check out all of the dirt inside.
MOTTO= change fluids and filters often...car will be happy
