Old 07-07-2005, 08:39 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
Question Am i doing something wrong...
I changed the faces on my gauges and at that same time i figured i would check and tighten the screws on the gauges. Since then ive had gas gauge problems, it doesnt work. I bought another cluster and swapped out the gauge and still nothing, so i bought another gauge and it slightly worked, well it went to 3/4 of a tank and hasnt moved since. Am i doing something wrong? Is there a special way to install and or set the gauge? PLEASE HELP
The Evil Sleeper
Old 07-07-2005, 02:19 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: Am i doing something wrong...
My guess would be to check the connections/wiring... If 3 different clusters are doing the same thing... U probably just knocked something loose back there...
Old 07-07-2005, 04:23 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
all these guage clusters ur buying.. b4 u test them are u throwing on ur new face plates first? u cant mess around with those needles, there are calibrated and if u muck wit them a little they will no longer be accurate. but if u didnt install the faceplates i would agree with Exempt.. u prolly loosened the pin for the fuel sensor on the back of the connector. gl man
Old 07-07-2005, 05:09 PM
91CRXTC's Avatar
not on all the gauges ive tried, just some, but i dont have to remove the needle to put the face on i just have to slide the face over the needles, but that also moves the needle so would that matter? my temp gauge still works fine so why just the gas?
Old 07-07-2005, 11:13 PM
Re: Re: Am i doing something wrong...
well like i said b4. just check the pins in the connector and make sure they are snug. sumtimes those harness's can be a bitch to work with not having much slack when connecting them and disconnecting them and u gotta give a lil tug on um. let us know
