Old 07-07-2005, 05:52 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Question egr mods
i hear talk of egr mods alot. what type are avalible for 91 4.3 tbi? and what are some benifits?
Old 07-07-2005, 06:38 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Restrictor plate... Will give slightly better gas miledge, and better low to midrange torque. Not used at WOT
Old 07-07-2005, 11:18 AM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: egr mods
What's WOT?
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 07-07-2005, 01:26 PM
crazycory1 crazycory1 is offline
wot = wide open throttle
Old 07-07-2005, 08:26 PM
jackass#1's Avatar
Re: egr mods
is a restricter plate just a bolt on or does it replace the egr?
Old 07-07-2005, 08:35 PM
rlith's Avatar
Re: Re: egr mods
Goes between the egr and the manifold...
Using a 1/4" piece of aluminum, take an EGR gasket and trace an outline of the gasket on the aluminum including the large holes.
On the upper pintle hole, drill to the same size as the gasket.
On the lower pintle hole start with 5/32.
Put a gasket on either side of egr plate when mounting. Now, if you set an SES code, simply drill the lower hole 1/32 bigger and repeat till the ses stops coming on. Be sure to clean the egr port on the manifold side before installing. Pick out carbon with a screw drive and run the engine for a minute before installing to blow out any loose carbon (rev a few times)
For the 96-2002 a fitting is required. 2003-2005 essentially the EGR mod is built in.
Old 07-07-2005, 09:09 PM
jackass#1's Avatar
Re: egr mods
alright thats easy enough. im going to do it. thanks!
Old 07-07-2005, 09:47 PM
OverBoardProject OverBoardProject is offline
Banned
Re: egr mods
I've never heard of that mod rlith.
in your opinion is it worth it to remove the EGR and bolt a plate in?
I don't have to worry about emissions where I live, and the EGR is the only emissions device left on my Blazer (with the exception of the PVC)
Old 07-08-2005, 07:07 AM
rlith's Avatar
Re: Re: egr mods
You don't remove the EGR, you add the plate between the EGR and the manifold. We have pretty strict emissions here in PA and we've never had mine fail emissions, and most people that I know who've done the mod have yet to fail emissions.
The reason? EPA standards on emissions call for at least a 10% N0x reduction. GM made there egr holes large enough so they wouldn't have to worry. When you do the mod you're restricting it down to epa standards. The ECM in your truck is pretty savy when it comes to the emissions standards programmed into it. As long as the SES light isn't set you'll most likely pass. GM finally wizened up to the fact that the large egr holes allowed too much carbon build up (see any given clogged egr thread) and actually built in the mod (for all intents and purposes) into their 2003 and up trucks.
Old 07-08-2005, 09:12 AM
Re: Re: Re: egr mods
I did this setup on my 98.I used sheetmetal though.
Click here
My $12.00 Sunfire
Old 07-08-2005, 09:29 AM
rlith's Avatar
Re: Re: Re: Re: egr mods
The problem with that though, to make it truly effective, at least 1/4" thickness should be used to create a proper tunnel vaccume.
Old 07-08-2005, 04:42 PM
jackass#1's Avatar
Re: egr mods
will this work on my 91 4.3z?
Old 07-08-2005, 05:32 PM
rlith's Avatar
Re: Re: egr mods
yes
