Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-06-2005, 11:47 PM
techm techm is offline
Question 89 warning lights charge, brake and lights on
Hi all,
Almost a month ago I noticed the the 3 warning lights would come on and off intermitently, but lately they are mostly on. I haven't noticed any change in the driving, but thought it might be worth checking. Any ideas of what maybe the cause?
Thanks
Old 07-06-2005, 11:57 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 89 warning lights charge, brake and lights on
When the instrument panel warning lights get flakey like you describe, almost always it's the alternator.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-07-2005, 01:36 AM
Re: Re: 89 warning lights charge, brake and lights on
The alternator was replaced recently. It's the second in 2 years actually. You are correct - the first 2 times all warning lights would go off as the battery gets low, but this time it's only those 3. Also when I had problems with the alternator the lights usually turned on when I press the brake.
Old 07-07-2005, 09:54 AM
Brian R.'s Avatar
Resident Chemist
Two alternators in two years? The source of that problem is the source of all your problems.
Old 07-07-2005, 02:13 PM
I was thinking the same, but I have no idea of what maybe the cause. The voltage regulator maybe?
Old 07-07-2005, 03:55 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Re: Re: 89 warning lights charge, brake and lights on
The voltage regulator is internal (inside the alternator). If you have a lifetime warranty, take it back and get another alternator to install. The failure rate of rebuilt alternators can be fairly high.
Mike
Old 07-09-2005, 04:18 PM
davemarfl davemarfl is offline
Yep, I'll second that. I've seen that too. Also for failing alternators the digital display on my 88 starts getting flaky, headlights dim when the brake is applied, the standard stuff.
Old 07-11-2005, 03:07 PM
typesix typesix is offline
Another vote for alternator. Replaced my 89 Camry alternator almost 2 yrs ago with same symptoms and solved the problem.
