Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 07-06-2005, 11:18 PM
blakscorpion21's Avatar
blakscorpion21 blakscorpion21 is offline
2nd and 3rd gen. 3sgte diffrences
what is the diff. between theese engines what on the 3rd gen gives it all that extra power over the 2nd gen.
Old 07-06-2005, 11:49 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2nd and 3rd gen. 3sgte diffrences
I think the later engines had more boost (13 psi vs 6.5 psi)
http://www.geocities.com/MotorCity/P...neEngines.html
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-07-2005, 01:48 AM
jaybratt jaybratt is offline
Send a message via AIM to jaybratt Send a message via MSN to jaybratt
Ahhh, I don't know about that. I may be confused but you are talking the st165 and st185. The st185 just has i think like 8 psi stock. I am looking to turning mine up to 15. I think the intercoolers have a lot of difference. If you are talking the st205, it has a water/air intercooler with lots of boost. I think that is the main difference. Someone just like totally shut me down if I am wrong.
Old 07-07-2005, 08:42 AM
yea im talking about st205/185
Old 07-07-2005, 03:18 PM
Ok, yeah the 205 had a water/air intercooler to compensate for the higher boost. I thind it was 13 or 15 or something. I don't know of any other major differences, maybe weight and chassis rigidity.
Old 07-07-2005, 09:32 PM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
the 2nd gen in st185 ~200hp
the 3rd gen in st205 ~260hp
the gen3 used a wta intercooler, run higher boost, and used a more aggresive timing, the turbo was different slightly as well, i don't think ther were any major mechcanical differences
Old 07-07-2005, 11:18 PM
Question
Are you sure on the 260??? I thought they had 240. Do you have a link with some specs???
Old 07-08-2005, 11:45 AM
yea they were 260.
Old 07-09-2005, 02:11 PM
it can be surprising how little changes can make such differences
if you are going for a 3sgte swap, while the st205 will give up more power off the bat, if you're planning to do alot of upgrades than i say get the 2nd gen
like if you have enough to get the motor drop it get a FMIC and some other upgrades than the 2nd gen cuz its going to be a little cheaper and with mods will do the same as 3rd gen
But if you only have enough to get and drop lthe 3rd gen and won't have upgrading money for a while you might want to go that route as you will have more power for the time being
