Won't Start
Put in a brand new starter, checked battery, turn key and all lights light up on dashboard, but no start. Also checked all fuses,, all look good. ????
Re: Won't Start
Re: Won't Start
need help with 98 izusu rodeo 3.2 unplug coils on bank1 ,does not change the way it runs
Re: Re: Won't Start
Re: Won't Start
Is it possible that you have the small wires backwards on the solenoid, or did not tighten the main wire to the starter good enough?
Re: Won't Start
Do you have a test light? With someone cranking, make sure you have power going to the purple wire connected to the starter solenoid
If none-could be possible ignition switch. |
Re: Won't Start
did you try the neutral start switch? once that goes you might not be able to crank in any gear.
