Old 07-06-2005, 10:58 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
turbo help!!!
I have a 95 gs-t. As of recently I just bought an aftermarket intake and installed it no problem. The car ran fine for the first day. After that for about the past two days the turbo has been acting really funny. When I step on the gas the turbo pretty much automatically spools up to full boost adding no power or minimal power whatsoever. I can drive on the freeway doing 80 and where normally I could step on the gas and have the turbo kick in and accelerate me pretty good, the turbo now just pegs out at full boost and doesn't move me any faster than I was before. Anyone have any ideas? I can hear the turbo spinning and everything but I'm not getting crap for boost. Could it be the new intake because everything was working fine before. Also the BOV now sounds different since I installed the aftermarket intake. Is that normal?
1991 GSX 2.3 Stroker
Old 07-06-2005, 11:46 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
My educated guess is that you have a boost leak from your new intake. Swap it back out with the stock one, and see what happens.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-06-2005, 11:59 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah sounds like a boost leak to me as well.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-07-2005, 03:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: turbo help!!!
Thing is there is no boost in the intake So unless another pipe was disturbed, it can't be a boost leak. An intake leak in that pipe would cuase a lean condition, but not the symptoms described here. First thing I would do is pull the intake pipe and see if the compressor wheel is damaged.
The BOV sound changing is normal.
What type of intake is this? FIlter? Pipe? Both? Some filters have been known to make the MAS read funny.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-07-2005, 06:43 PM
defiancy's Avatar
Re: Re: turbo help!!!
I found out what it was. It was the intercooler piping had kinda broke when I pulled out the stock intake. So I just loosened the clamp reseated it and it works like a champ. But thanks for the idea's
