Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 07-06-2005, 10:35 PM
mikau32 mikau32 is offline
Question engine light on??
i just got back from a 5 hour drive and my engine light turned on. i have a SVT focus. the car is running fine. the light is not blinking, which the manual says is bad. what might be the problem.
Old 07-06-2005, 11:11 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
Re: engine light on??
This is sort of like going to the doctor and saying that you don't feel right and then asking for a full diagnosis without any sort of check...(weird example, I know, but I'm tired, so). Just go to the dealer, or Pep Boys, or basically any good garage, and have them run a scan to see what error is causing the light to stay on.
-Chuck
Old 07-07-2005, 01:39 PM
I plan too, just wondering if ne one else light has come on after a long trip.
Old 07-07-2005, 06:10 PM
mlw35405 mlw35405 is offline
There is a way to pull up the trouble code using the trip odometer. You just can't turn the light out that way. Here;s how:
With key in ignition and ignition off, push and hold the trip reset button. Keep holding it down and crank the car up. Hold it down until "TEST" appears in place of the trip odo, then let it up. This puts instrument cluster in test mode. Push button again, GAGE displays. Push again and Bulb displays. Push again and this will display your DTC codes. Write the code down and post it here or look it up on Google. You can keep pushing the button to scroll through other test areas, such as speed and RPM's, etc. As soon as you turn the key back off everything goes back to normal. Hope this helps!
The young and the young at heart wait,
But the wait never ends in the soul,
When you feel like its all blown away,
Independence has come,
And into the night I go...
Old 07-07-2005, 10:17 PM
Post
thanx a lot. i tried it, it said dtc- NONE. im taking to the shop soon, haven't had the time. its not my primary car ne way only drive it 3 days a week, if that.
thanx again
Old 07-07-2005, 10:32 PM
One more thing. will the light stay on untill some one turns it off, or will it cut off by it self.
My rodeo's cuts of by itself,... The other day i thought i had my foot on break, but was on gas..reved up really high, and the light cut on, but went off like 20 mins later.
Old 07-09-2005, 10:00 PM
focusyn focusyn is offline
Re: Re: engine light on??
After a long trip, it could be an O2 (oxygen) sensor or something related to the emissions system. A trip to the dealer, repair shop, or buying an OBD-II code scanner from an auto parts store for about $50-100 is the only true way to know whats wrong.
