Old 07-06-2005, 10:50 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
A/C Problem...
Well, Ill start off by saying I have the problem with my RPMs dropping when I idle. The car just about stalls but then the RPMs hop back up. I deal with this problem, but now I think I have a bigger one.
Heres the story:
Im off to my GFs house, A/C is on and Im goin about 80ish, and for no reason at all, the A/C stops working. So I think oh well, its just out of freeon. I think Im wrong about this too.
So as Im leaving tonight, the car isnt warmed up anymore and I start it, but I hear a squeeking noise. Its not a constant noise, just kind of like 3 squeeks every second or 2. I usually get this sound when I start my car in the morning but not this loud. So I try the A/C when Im driving about 20mph and it was cold for like a minute about. Then it shuts off and is just blowing outside air. So as the A/C is on, I hear clicking noises, about 2 every 3 or 4 seconds, and every time the engine clicks, the RPMs drop just a little bit, like Im idleing. This has never happened before. So after the car is warmed up and Im sitting at a stop light, I try the A/C again, still no cold air, but now the car doesnt drop in RPMs when Im idleing nor while Im driving slow.
Hopefully I described everything good enough so you guys know what this problem is. I need to stop by my mechanic and if the compressor is broken....Im taking it out along with everything else A/C related to get a nice little weight reduction.
Also, it doesnt do it if I turn up the A/C and put the heat on all the way.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 07-07-2005, 03:39 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
lol you are going to hate hearing this...that just happened to me about 2-3 weeks ago but its your a/c compressor. the squeeling is the belt about to go out and the ticking(which will get ridiculously worse) is the sound of the clutch in the compressor shaking around. Eventually you are gona have to either cut the belt(which is what I did) or get it replaced, at a jiffy lube or mobile(etc) you are lookin around 2 grand. at a local shop or doing it yourself you are looking around 700-1000. try to regulate your a/c use.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 07-07-2005, 03:54 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: A/C Problem...
or you can get a used ac compressor for $100 at an autoparts junkyard (guranteed good) and save $600.
95 Talon TSI AWD
97 Eclipse GST
Old 07-07-2005, 03:09 PM
Re: A/C Problem...
Is it possible to completely take it out and run the car without an A/C compressor?
95 Eclipse GS-T
Currently:
Soon lol
Old 07-07-2005, 03:11 PM
Turbodog97's Avatar
Just a Neon
well you dont have to take out the compressor...just cut the belt eventually. If u cut the belt your car will run fine, Im not sure though if you take the whole unit out
05 Srt4
97 Mx-5
Old 07-07-2005, 03:26 PM
Re: A/C Problem...
I would just for the weight reduction and make the car a bit quicker
95 Eclipse GS-T
Currently:
Soon lol
Old 07-07-2005, 04:19 PM
Re: A/C Problem...
yes the car runs perfectly fine without the ac compressor. i took one off for a guy while we were waiting for his other one to be shipped. i just capped off the lines and he's been driving it for about 2 months.
95 Talon TSI AWD
97 Eclipse GST
Old 07-07-2005, 04:25 PM
Re: A/C Problem...
Well, just stopped by the mechanic, the compressor is shot. Is there a faq on taking out the compressor or should I just take it out along with all the lines or what?
95 Eclipse GS-T
Currently:
Soon lol
Old 07-07-2005, 05:35 PM
mobil_12 mobil_12 is offline
I would just cut the belt incase you ever plan to fix the a/c in your car.
You should be able to remove the compressor without any problems. The only thing you might run into is if there are any brackets attached to the compressor. You can also remove the condensor, drier, lines, and evaperator. That will save you at least... 15 pounds. Seems like a lot of work for 15 lbs.
Old 07-07-2005, 09:03 PM
Re: A/C Problem...
for me the compressor wasn't very hard to get off, but it was a bitch to get out of the area where it was at. i had to pull it out through the top right next to the intake manifold.
95 Talon TSI AWD
97 Eclipse GST
Old 07-07-2005, 09:46 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: A/C Problem...
yeah that's what i did too, when i got my car, the ac compresor was there , everyting hooked up but it wasn't working, so i took it out about 4 months ago, and my car is runing fine, it wasn't that that hard to take it out, but it's being a bitch to put it back , lol,
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-08-2005, 12:55 AM
Re: A/C Problem...
I plan on leaving it out, Ill end up doin it after I move to VA in a couple of days
So basically I just unbolt everything going to the compressor and Im done?
95 Eclipse GS-T
Currently:
Soon lol
