Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-06-2005, 07:50 PM
Flambaosting Flambaosting is offline
420a and srt-4 swap
forgive me if i sound crazy but i have heard that you can put the srt-4 motor in the 420a eclipses because the mounts are basically the same and would feet well. i heard it's in the works already. what do you all think?
Old 07-06-2005, 11:27 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: 420a and srt-4 swap
the SRT4 motor is backwards compared to the 420A in the Eclipse.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 07-07-2005, 12:09 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Some of the older neons (95 to 99 I believe) had the 420a so yes a 95-99 Neon 420a could go into a 95-99 RS/GS or vice versa. The SRT4 engine is not the 420a so it could not be directly swapped.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-07-2005, 11:52 AM
if it gets done that would be a nice sleeper though wouldn't it?. and yeah it's backward but i heard something about altering the firewall to make way for the srt's turbo.
Old 07-07-2005, 01:48 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
It would be nearly as hard as doing the 4g63 swap. You would still need a different transmission and ecu, among other things. Why not just buy a damn srt-4.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-28-2009, 08:12 PM
mopowerman mopowerman is offline
Post Re: 420a and srt-4 swap
the swap can be done the motor mounts don't line right up, but as for it being backwards my 420a in my 95 eclipse sits the same way as the srt4 in the neon. It would be backwards in a 97-99 when the engine was flipped around.
Old 09-28-2009, 08:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
This is not true. The engine was never flipped around. The 420a eclipse has the tranny on the driver side as does the srt4 motor. However it will take a lot of fabrication to make it work. There is a 2.4 swap for the 420a that bolts right in with the exception of a few pieces. This would be a far better swap than the srt4 motor.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-29-2009, 09:12 AM
what i should have said was that some eclipse had the trans on the pass. side of the car not the 420a engine car that was my bad.
SAMSUNG-SGH-A867/A867UCHJ3 SHP/VPP/R5 NetFront/3.5 SMM-MMS/1.2.0 profile/MIDP-2.0 configuration/CLDC-1.1 UP.Link/6.3.1.20.06.3.1.20.0
Old 09-29-2009, 10:23 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
All models EXCEPT for the 420a had the motor sitting the other way.
Long story short, this thread is over 4 years old and the original posters and responders aren't even on here anymore. Point is, it's just cheaper in buying a SRT4 if you want one. Unless someone could show a writeup or something, you're on your own.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-03-2009, 09:49 AM
98spyderman 98spyderman is offline
ummm ya why would would u want to do a srt-4 swap in to a dsm? that makes no since. just build the gst motor and there you go. forget the srt-4
