Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 07-06-2005, 04:47 PM
GreenCar GreenCar is offline
1988 Lebaron electrical issue
My daughter has a 1988 Lebaron Coupe which has an electrical issue I can't seem to solve - Whenever the doors are opened or the dome light is turned on with the headlight switch, the power to the radio and the information center cut out. As soon as the door is closed, the power returns to the radio. Also, randomly when the key is removed from the ignition, the backup power to the radio also cuts out, resetting all of the presets and the clock.
Ground to the battery and engine block are good, and the fusebox looks good and not corroded. Any ideas?
GreenCar
Old 07-06-2005, 10:43 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1988 Lebaron electrical issue
sounds like you have two circuits that are crossed together, like the insulation has rubbed off the bare copper is rubbing up against each other, causing a cross-short.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-17-2005, 06:57 PM
mrfixit64857's Avatar
mrfixit64857 mrfixit64857 is offline
Mine was giving me problems like this... and it was the "always hot" fusible link loacated near the driver's side firewall under the hood... I replaced the entire link and it went away
What is life, if not to be laughed at... or caught in a Ford?
have mercy on me...I gave Oil today!
