Old 07-06-2005, 05:06 PM
ritas ritas is offline
Send a message via Yahoo to ritas
Red face my 92 camero rs
i have a 92 camaro that acting like its not getting gas when i try to crank it.they have put a coil fuel pump and air filter as well as spark plugs. we have even bought a new key for it because sometimes i can turn the key and try to crank it and it wont do anything almost like the battery is dead but the air conditioner and the radio and every thing works!!!!!!! help
Old 07-06-2005, 05:24 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: my 92 camero rs
I'm tempted to say the ignition switch at the base of the steering column.
You could double check by looking for voltage (12 or better) on the "s" terminal wire (s/b purple) of the starter while someon e turns the key to the start position.
Old 07-06-2005, 09:14 PM
ct91rs ct91rs is offline
Re: my 92 camero rs
does this only happen when its hot, or all the time?
Old 07-07-2005, 01:04 AM
Morley Morley is offline
Ignition module.
Old 07-11-2005, 08:08 PM
Unhappy Re: Re: my 92 camero rs
it happens mailny when its hot!!! or i have drivien it along time but i can jump it off and its fine!! they have changed the spark plugs and everything. now it still wont crank. it acts like it trying to but it wont turn completely over .
Old 07-11-2005, 08:14 PM
Question my 92 rs camaro.
my camaro is also showing something called- inflat rest, when i try to crank it. ----- ritas.
Old 07-11-2005, 09:20 PM
Re: my 92 rs camaro.
The inflat rest or air bag light, should go off once you start the car, unless something is wrong in that system. It should be unrelated to your starting problems.
If it doesn't turn over at all it could be a problem with the starter solenoid. If it has trouble turning over (the starter motor actually turns over the engine, but doesn't seem to have enough power) and the battery is ok, and it will start with a jump, I'd say there's a good chance your starter is kaput, drawing too much amperage.
If the problem's that it turns over but doesn't fire, you might want to look at the ignition module as morley suggested.
