Old 07-06-2005, 02:17 PM
Eezziebaby Eezziebaby is offline
Send a message via AIM to Eezziebaby
DRL's
My boyfriend has a WRX and he found a fuse/switch that could be removed to turn off his DRL's (daytime running lights) and now I want mine off... Does anyone know how to do this?
Old 07-06-2005, 09:01 PM
Tonyr's Avatar
Tonyr Tonyr is offline
What year car?
Old 07-06-2005, 09:29 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: DRL's
Well Tiff. First thing you need to do, is get your boyfriend a new car.
Try this;
http://macgp.clubgp.com/howto/appearance/drl/drl.htm
Old 07-07-2005, 10:05 AM
Re: Re: DRL's
Try this;
well sweetie I love his car... thanks for the link...
Old 07-07-2005, 10:07 AM
Re: DRL's
Originally Posted by Tonyr
What year car?
I had a 1997 SE 3.8 and this old man hit me in the back... So now I have an 1999 GTP supercharger
Old 07-07-2005, 06:31 PM
Tonyr's Avatar
Re: DRL's
you can also pull the fuse in the glove box. Just check to see what fuse number it is....unless I am mistaken.
Old 07-07-2005, 07:41 PM
Re: Re: DRL's
No that's true. But if you pull the fuse, you lose your auto lights.
Old 07-07-2005, 10:30 PM
Tonyr's Avatar
Re: DRL's
true...i turn my lights on manually. I can see the lights in my dash dim when they are triggered to turn on.
Old 07-07-2005, 10:50 PM
LisaGT LisaGT is offline
drl's
Thanks for the link, I can turn my driving light off. I am thinking about sellig my car though... for a 2000 gt 3.8 series 11 it should not be having rack and pinion problems. If thats what it is.
Old 07-08-2005, 09:10 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: DRL's
On many GM cars, if you attempt to defeat the DRL's, it will cause one headlight to wink out. Make sure all your lights work after pulling that fuse, we don't need to give the authorities a reason to pull us over.
Old 07-09-2005, 01:42 PM
mike561 mike561 is offline
Re: DRL's
hey if i do pull a fuse also, which one would it be? i dont care if i lose my auto lights, my old car had manual lights anyway so im used to turning them on myself anyway, i got a 98 GP
Old 07-09-2005, 02:36 PM
Re: Re: DRL's
you have to look in you manuel for the number... the link that was given to me didnt work so I just looked in the manuel for the number and pulled the fuse... that worked thanks.
Old 07-09-2005, 05:45 PM
Tonyr's Avatar
Re: DRL's
In my 98, the fuse box is on the right side of the glove box. The fuse is the very bottom left one. Don't think there is an actual number but the book shows which fuse is for the DRL's.
Old 07-10-2005, 12:21 AM
Re: DRL's
ok, i found the fuse that goes to the automatic headlights, only problem is that the a/c display (i have the digital thermostat in my gp) and the gauge above the radio goes out (the one that shows what doors are open etc.) along with it, so im taking it its on the same fuse, so i just left it in, but i did disconnect the DRL wire though.
Old 07-10-2005, 08:40 AM
Tonyr's Avatar
Re: DRL's
mine was a little 10 amp fuse I think. Nothing else went with it. I have a 98 GTP. Not sure it it differs from your 98 fuse panel or not.
