Old 07-06-2005, 01:41 PM
toicy4ya's Avatar
toicy4ya toicy4ya is offline
Removing on/off switch with reverse indiglos?
Sup guys,
I want to eliminate the on/off switch that came with my reverse indiglos so that the indiglos automatically turn on when I turn on my headlights. Anyone ever done this or know how to do this?
currently they're installed but I need to hit the on/off switch everytime I turn on the headlights. Any feedback would be greatly appreciated.
Thanks
99 Eclipse Spyder GS
Old 07-06-2005, 03:03 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Removing on/off switch with reverse indiglos?
Seems to me like you should be able to cut the switch out of the circuit. Is it in a wire? If so, bypass the switch and hook it up to the lights. That should work for you.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-06-2005, 03:54 PM
toicy4ya's Avatar
It's actually two additional wires, However the red (power) wire from the indiglo's is already set up to a 12 volt. I dont think attaching the two additional wires will do anything.
Old 07-06-2005, 04:43 PM
david-b's Avatar
Dave is THAT guy
It seems like you can splice the wire (or just cut off) the switch. If you can, post a pic so I can see exactly what you mean. Thanks
75 Monte Carlo
Old 07-06-2005, 10:08 PM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Re: Removing on/off switch with reverse indiglos?
if it's like mine it's a momentary swtich. You can cheat by just connecting the two pins without the switch on it. Then when power is applied the switch gets thrown.. when power is removed it turns off. Not sure if thats the safest but it works for me .
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 07-07-2005, 02:07 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
find wherever your power source is coming from and just hook it up to the ignition wire. leave the switch "on" at all times and then hide it and just use your headlight switch to turn them on and off with the lights.
95 Talon TSI AWD
97 Eclipse GST
Old 07-07-2005, 07:21 AM
toicy4ya's Avatar
Thanks guys,
I think its like what nova mentioned. It's not exactly a toggle switch, its more like the switch you need to press to turn on and off. When I installed it, I did try cutting off the switch all together, splicing the wires and then connecting them but when I turn the headlights on/off it didnt do anything. I think i'll give it another shot though.
