Electric Mayhem
A couple weeks back I was driving and check engine light came on and it seemed the transmission was slipping. I had it towed and no one could find out what was wrong. Now I know it is an electric problem, but need to know how to fix it. Currently, the check engine light is on, but everything runs fine, fluids are okay and car doesn't run hot. Also, the airbag light will stay on and occasionally my entire panel, gas gauge, fuel, oil level, etc. will be dead. I then can turn the air on and then off, and everything goes back to normal, but the check engine light.
I am driving a 1998 Jeep Cherokee Sport with 127 K. |
Re: Electric Mayhem
If it is like my 92 cherokee: To do that just turn the key from OFF to RUN three (3) times within 5 seconds, leaving the key at RUN the last time. Then watch the check engine light ... it should flash the codes to you (like flash - delay - flash - flash for a 12 code). If you get the codes, post them here and I (we) can probably help identify the possible problem. Take Care,
Greg A. 2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010) 1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010) |
Re: Electric Mayhem
There are other posts on this site about these two issues. |
Re: Electric Mayhem
Mine did something like that, but, I would turn the heat on, the lights would go real dim and the engine would die, it wouldn't start or even click, the seatbelt light or anything in the car would work almost as if there was no battery in it. a few minutes later it would come alive again and everything would be normal... happens almost everytime I touch the heater controls, unless I ease it up from the lo setting to the high one... I replaced the battery, heater motor, heater switch, alternator, I nor the dealer can figure it out?
Black 99 Jetta GLX VR6 Black 92 BMW 525I Blue 95 GMC Jimmy SLT 4.3L VORTEC V6 (Sold... Junk) Green 98 Jeep Cherokee SE (totaled Electrical fire) Red 95 Jeep Cherokee Sport (Gone) Green 93 Jeep Grand Cherokee Limited (for sale) [email protected] "Racing a ricer is just like competing in the special olympics, even if you win your still retarded" |
Re: Re: Electric Mayhem
NSS does....but that is not your problem. Skip the dealer and find a mechanic you can talk to...not the service writer (salesperson) or the good looking girl that types your work order into the computer. Check the VEHICLE GROUND. |
Re: Electric Mayhem
Well I got the codes and although I can't remember them exactly, the problems were my (according to the codes puled) shift solenoid circuit and a malfunction in the transmission control module. The mechanics (family friends and highly trusted) have the car again, going on the second day. They are trying to find the problem, they seem to think that replacing the transmission would fix it, but do not recommend it. They hear 'something' in the engine and feel that the engine may not last too terribly long. 128K, is this typical for a Jeep. I just may have to jump ship after my first one. Not a single problem up until my radiatior, then this and now possible engine problems. Anyone else have these problems?
I did a search for you for NSS on this forum....start here. This causes the code P0705. ********************************* This tip saved me $2000. Skipping, stalling, OBDII 45, or P0705. clean you NSS http://www.jeepin.com/features/nss/index.asp XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX The 4.0L is renown for lasting a long time......200k plus miles. But to be truthful ...other thing such the AC and other electrical things go bad. XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Did a search on your air bag light......found the following... ********************************************** Faulty airbag control module,....check with your dealer to replace for free......97-2000 cherokee's are affected. Recall#860 ************************************************ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Try this link: http://www.dot.gov/affairs/nhtsa2500.htm The dealer needs to do this. END.....HOPE THIS HELP YOU. |
Re: Electric Mayhem
Well actually the airbag light was solved my hitting the dash. After that, my gauges worked and the Check Engine light came on, that then resulted in the car working as before. It is only intermittenly too.
http://www.dot.gov/affairs/nhtsa2500.htm |
