Old 07-05-2005, 11:28 PM
shorty6049 shorty6049 is offline
Send a message via AIM to shorty6049
99 GP GT Radio Problems??
I just recently bought, Havent even brought it home yet, a 99 gp gt,
the display on the radio ( standard with only treble and bass controlls) is not working though, well, to clarify, it works, but there is no backlight, so you can just BARELY see it, is there any way to fix this????
otherwise, I have a stereo with equalizer from another grand prix of the same year, can i swap it out for that radio? or wont it fit in the space??
how do i disable theftlock if i do that then? im not sure if its turned on or not.
Old 07-06-2005, 02:30 PM
Eezziebaby Eezziebaby is offline
Send a message via AIM to Eezziebaby
Re: 99 GP GT Radio Problems??
It shouldnt be a problem to swap but the light is dim because there is a module that sits behind the radio that needs to be changed... when i got mine out it look like it melted over time... with 97 a lot of censors and modules needs to be changed
Old 07-08-2005, 01:01 AM
ok, but is there a way to turn theftlock off, cuz im not sure if it is on or not, and i dont wanna risk it, if i try to swap radios, and then something goes wrong and i cant fix it,
help???
Old 07-08-2005, 08:36 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
look on the face of the radio. If the theftlock light is on, then it is activated and you need the code before disconnecting. The radio with EQ is a direct bolt in and will fit perfectly. Also, the radio display has a lightbulb behind the led, and they can burn out in time. It's an odd bulb, but if you can find one, it's user replaceable. I did it in my fiance's Trans-Sport. Found the bulb at Radio Shack I believe but I don't remember what the part number is.
Old 07-08-2005, 09:15 AM
wylie's Avatar
wylie wylie is offline
This was covered in detail in a previous thread
Heres the results of search I just did I thought I could spot it for you
but its in there some where.
http://www.automotiveforums.com/vbul...archid=1035033
Old 07-11-2005, 05:32 PM
mike561 mike561 is offline
hey i had the same problem in my sterio, its an easy fix, heres a link from another thread to show you some good instructions on a fix http://users.adelphia.net/~bpaskevic...amp_repair.htm
