Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-05-2005, 11:19 PM
DavisT DavisT is offline
Engine light on
My 98 camry engine light on and I bring to autozone this week and they gave these code: P0135, P0141, P0155. Someone please tell me what are problems with these codes. (Also, I brought my car to Toyota dealership in Arlington-Texas last year and they told me o2 sensor were bad and they replaced 3 sensors its but the engine light was still on and then they told me that ecm is bad. I give up).
Thank you very much.
Old 07-06-2005, 09:05 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Engine light on
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
Since you've replaced the HO2 sensors, there must be a problem with the heater circuits or the detection of the current in the heater circuits.
In this case, they may be right - bad ECM. That is the only thing I can think of. Hard to believe all the heater circuits went out at the same time.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-06-2005, 11:45 AM
Re: Engine light on
Is it easy to replace ECM and where is ECM locate? Also, where I can get good price ECM? Thank you very much.
Old 07-06-2005, 12:10 PM
Brian R.'s Avatar
Resident Chemist
Re: Engine light on
ECM is best found used at a salvage yard because they are quite expensive. It is normally on the passenger side of the interior inside the kick panel. Easy to replace, it is just an electronic box with a few connectors.
Don't run off and buy one just yet. I may be wrong and you would be wasting money. Wait and see if anyone else has any ideas.
Old 07-06-2005, 12:24 PM
Mike Gerber Mike Gerber is online now
AF -Advisor
Re: Engine light on
Have you tried having Autozone clear the codes to see if they return? They could be left over from when the dealership replaced the 3 O2 sensors and forgot (or just didn't bother) to clear the codes from the ECM's memory. They probably will return, but it's worth a try. It would be free except for your time. If the codes return then I'm thinking along the same lines as Brian; bad ECM.
Good luck.
Mike
Old 07-06-2005, 01:31 PM
Brian R.'s Avatar
Resident Chemist
Re: Engine light on
I don't believe he ever needed the three HO2 sensors, so replacing them would have no effect. Codes would still be there if it's the ECM.
Old 07-06-2005, 04:49 PM
Re: Re: Re: Engine light on
Autozone clear the codes but engine light is back on again. Should I try to replace the ecm?
Old 07-07-2005, 11:05 AM
Devonsmom Devonsmom is offline
Re: Re: Re: Re: Engine light on
my 1996 toyota Camry engine light came on after a long trip
i have no idea why the car runs fine can anyone help?
Old 07-07-2005, 02:19 PM
Brian R.'s Avatar
Resident Chemist
That's my opinion, but there may be a cheaper solution. See if there is someway of borrowing one to test yours.
Old 07-07-2005, 02:20 PM
Brian R.'s Avatar
Resident Chemist
Re: Re: Re: Re: Re: Engine light on
Get the codes from the ECM with a OBDII tester. Find out what system is causing the light to be on.
Old 07-07-2005, 03:50 PM
AF -Advisor
Re: Re: Re: Re: Re: Re: Engine light on
Go to Autozone as the original poster did. They will read the codes for you for free. Then report back here with the codes and someone can probably give you some direction to take to solve your problem.
Mike
Old 07-07-2005, 05:09 PM
I appreciated your help.
Old 07-08-2005, 07:28 AM
i unplugged my battery and plugged it back now the light is off
Old 01-17-2007, 12:15 AM
jd4irish jd4irish is offline
Re: Engine light on
My grandmother-in-law owns a 2005 Toyota Camry. Recently her check engine light comes on. I know a lot of imports used to install a DIY diagnostic bay that only required a jumper cable and a code sheet to find out what is wrong. Is this still true? If so where is it? and what are the codes?
Thanx!!!
Old 01-17-2007, 01:53 PM
AF -Advisor
Re: Engine light on
Thanx!!!
This is no longer true for OBD2 equiped cars. That is, cars from model year 1996 and newer. However, there is still some good news. If you have Autozone parts stores in your area, you can take the car to them and they will read the code for you for free. If you don't have Autozone in your area, call around to other parts stores and ask them if they offer this free service. Then come back here and post the code and someone will be able to give you some direction. In addition, when you do come back with the code, give us some other information, like which engine and how many miles are on the vehicle, along with anything that has been done lately to the vehicle.
Incidently, if the car is less than 3 years old and has less than 36,000 miles on it, it should still be under warranty. If that is the case, take it back to the dealer and let them deal with the problem.
Mike
