Old 07-05-2005, 09:29 PM
Prov5 Prov5 is offline
Angry Help - No brakes!
My son just put new front rotors and pads on his Chevy 1500. He had to drain some brake fluid but put new back in. He pumped the brake pedal until it got firm then went for a test drive and zero brakes. He has replaced pads before and with no problems. The sop put in a new master cylinder a few months ago. Does anybody have any ideas. He followed the mannual for doing this step by step and says everything went oK. Your help is greatly appreaciated. Thank you
Old 07-05-2005, 10:11 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Help - No brakes!
Did he bleed the brakes?
Old 07-06-2005, 05:30 AM
Re: Re: Help - No brakes!
Not sure but will ask him. Do the brakes need to be bled after he was done and fluid added? He said the brake pedal now goes all the way to the floor? Thank you.
Old 07-06-2005, 08:06 AM
timsch75 timsch75 is offline
The first thing is definitely to bleed the brakes. There are plenty of sites online to give directions on how to do it. No, you don't necessarily have to bleed every time, but considering he did drain some fluid and you don't say where he drained it from, it is a good bet that the brakes need to be bled.
Old 07-06-2005, 07:10 PM
Thanks for everyones help - the bleeding was not done - everything works fine now - Thanks again!!!
