Old 07-05-2005, 09:19 PM
Tigrao Tigrao is offline
93 Escort A/C Cycling Switch
Ever since I got my 93 Escort (3 years ago) the A/C has never worked right. I would turn it on and leave it on all the time and the compressor only engaged like for five minutes once a week. I checked the pressure in the lines when the car was turned off and it was over 140 PSI. So I figured that low freon wasn't the problem. I decided to try and bypass the A/C cycling switch. I unplugged the switch and put a paper clip in. Sure enough, the compressor kicked on and the air got ice cold.
My question is this: Would it be really stupid to just leave it like this and just turn off the A/C like every 5 - 10 minutes to let the system cool down? I realize that it wouldn't turn off by itself if I leave the cycling switch bypassed. Maybe this is just a really stupid question in the first place. I just don't want to have to go through the trouble of replacing the cycling switch.
Old 07-05-2005, 11:00 PM
Re: 93 Escort A/C Cycling Switch
Well, after more investigation, the A/C control switch isn't the problem after all. I drove down the highway for ten minutes and the compressor switched off. It never came back on. I stopped off the road and readjusted my paper clip, thinking that it had come out. Nothing would work again. It was all a coincidence.
I came back home and started messing around more. I noticed that when you push the A/C button in the car a brown relay box right next to the passenger door clicks. I tried hitting this box lightly with my flashlight. It worked! The A/C kicked on!
This is the box I am talking about:
I can't find any information on what this relay box is in my repair manual. It doesn't look like it would be too difficult to replace it. Can anybody tell me what this box is exactly so I know what new part to get?
Old 07-06-2005, 03:08 PM
quickywd01 quickywd01 is offline
Look on the box itself, it should have all the info you need. Ford usually prints info on their parts. If it doesnt then take it to your service department and the guy there will get you what you need.
Nissan, Subi, Yoter, Ford
Old 07-07-2005, 06:17 PM
mlw35405 mlw35405 is offline
Go to a local parts store and ask for an a/c relay. If they ask, its the one under the hood. Costs about 10 bucks, just make sure they look the same. I had to replace mine about a year ago, got it at Advance Auto Parts.
Old 07-08-2005, 05:58 PM
Mrajp Mrajp is offline
Actually, according to Chilton, the AC relay is on the left
Old 07-10-2005, 04:20 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
I think this is the A/C cut-out relay. When you push the gas pedal to the floor it cuts of the A/C for max power when passing or accelerating.
I have a '93 and my A/C problem was a clogged orofice. I think a new one was $10 at AutoZone.
Old 07-10-2005, 04:23 AM
If the orofice is clogged then I think the clutch shuts off because there is TOO MUCH pressure. Not because the pressure is low.
Old 07-12-2007, 11:08 AM
Paperclips are awesome.
Old 07-12-2007, 04:20 PM
Arrow '94 escort lx
R-134a+ is amazing.
