Air Conditioning Blows warm until you start driving
The AC in the truck is blowing out warm when you aren't moving. Once you start moving the air cools off. When you stop it starts blowing warm again. Any help is greatly appreciated.
that's normal, you have to get the a/c pump going before it gets cold
NO...we have owned the truck for 3 years and this is a new problem. Before you could start it up and it would blow cold as long as you wanted. Here in Texas we do this to cool the vehicle off before we get in it. However, now the AC will not blow cold until you have been driving about a mile or 2.
Anyone else? |
It should get cold almost immediately.
Is the refrigerant charge low?..if not check the compressor cycling switch. |
Re: Air Conditioning Blows warm until you start driving
It SHOULD get cold almost immediately but it does not. Checking the compressor cycling switch involved what? Also, why would the compressor not cycle on until you start moving?
Again...is the refrigerant charge low?
ac Clutch is bad
![]() '99 Silverado 4 x 4 bunch of goodies |
Check your charge level. Check your fan at the condenser. Make sure the condenser isn't obstructed.
You need air flowing through your condenser to cool it. It does when you are moving and the fan would cool it when you are stopped. Sounds like the fan to me. Pop the hood, turn on the air and see if it is runnung.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold) HIS----> 2003 Dodge 1500 HEMI QC 4X4 |
also check the Condensor Fan fuse .... My 02 popped a code that said it was the Condensor fan relay once ... it wasn't the relay.. dealership said it was the fan and wanted big $$ to replace it ... I took it home done a check myself just looking for stupid stuff and the fuse was blown.... just a thought...
To test - mist a garden hose spray across condenser at idle- see if cooling improves- this will verify lack of good airflow across condenser- and the need to either replace clutch fan or clean condenser....
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
Your condenser fan is not working next to the radiator.
