Hi ... Yesterday my 1996 Grand Caravan Se gave me a surprise when I turned on the car. None of the dash panel indicators are working. The speedometer stays at zero while I"m driving. The gas gauge is stuck where it was before I drove and filled up the tank.
The gear indicators are gone too; so I don't see which gear I'm in. My A/C has been going on/off for two summers now. Sometimes it works on low, sometimes on high, sometimes not at all, sometimes it's just fine. My husband checked the fuses and thought they were ok; but he doesn't really work on my car. I was hoping for any/all suggestions before taking it to get fixed somewhere. Thanks, Kathy
Re: Gas gauge, speedometer, odometer dead!
Re: Re: Gas gauge, speedometer, odometer dead!
That's just what it was! The panel is just fine now! Thanks so much!
Kathy Quote:
I was suprised with my 2000 that when the rear wiper motor blew a fuse the gauges all went dead the odometer stopped but it still ran just fine. Wish i had known that before my mileage exceded the warranty lol. But what supprises me is that after owning this for 2 years i just found out the EATX SHUTDOWN RELAY IS NOT IN RELAY CENTER?
it worked for me too! i can't believe it you just save me 140 bucks! my dome lights my windshield wipers my gas gauge were all not working and wala they do now! Do you have any ideas about a speedometer not working? Should i replace the vehicle speed censer? |
Re: Re: Re: Gas gauge, speedometer, odometer dead!
I removed the EATX fuse by accident. Now I have the same problem as described above. But it didn't work after I remove the IOD fuse and put it back. Is there any trick for it? Now my 96 Caravan works only in the first gear, no gear indicator and Check engine always on. Please heeelp me.
river |
I am having the same problem with my 91 voyager. None of my gauges are working and the check gauge light is on, I've changed the fuse for the gauges in the fuse box on the drivers side. Sometimes the "dummy" lights go a little haywire but other than that the gauges are my only problem. Where would the IOD fuse be located on my van? I can't find a fuse box under the hood anywhere.
I couldn't find the IOD fuse (1992 Voyager) so I just disconnected the battery and that worked. Just had to re-boot, I guess. Symptom: Check Gages light on, temperature and fuel gauges dead, speedometer dead, instrument panel light dead, electric door locks unlock but don't lock (I found the connection between gauges and door locks in another blog as well). Thank you guys! It's great to actually find solutions! I'm putting this on Wiki Answers too, only questions there.
My 92 voyager had same problem. Check gauges light was lit and speedo, fuel and water temp gauges were not working. Dash lights were out and intermittant wipers were not functioning. I disconnected the negative cable to the battery for 20 minutes. Now all is well again. Seems that there was a static charge build up on the body control module. Disconnecting the battery allowed that static to discharge.
