Wont Start Ran Fine! Help!
Hey ok I was driving at about 55mph and my 87 CRX HF just shut off. Ran fine until then. I towed it home and replaced the coil and rotor. Still does the same thing. It gets gas, but no spark, from anywhere. Any ideas?
Re: Wont Start Ran Fine! Help!
Just a suggestion... Pull your top timing belt cover off and see if your timing belt has broken. That could cause the dizzy to not rotate and won't give you spark. If nothing else, pull the cap off and have someone watch the rotor to see if it spins when you turn the key. That will tell you basically the same thing. If all else fails, your distributor could have gone out. Check those things first and get back with us.
"Short, sweet, and to the point" 1987 CRX Si - Project Si 'RexSi' 1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL. 2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ? |
Check your ignition switch, main relay and fuses (especially the main fuses in the engine bay!). Also, make sure your battery terminals and cables are clean and tight.
