Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 07-05-2005, 11:14 AM
MaxBURNOUT MaxBURNOUT is offline
Send a message via AIM to MaxBURNOUT
Issues with alternator
Anyone have any suggestions on removing the altinator. its a pain to get to.
Old 07-12-2005, 08:44 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I believe you can get the alternator out on a 2.0 beetle w/o taking the intake manifold out. There are 2 12mm or 14mm bolts that hold the alternator in to the bracket that need to be taken out. Then use a prybar to pry the alternator out, dont for get the small 8mm nut that holds the harness to the alternator.
When you put it back in you have to press the brown bushings out a little so the alternator will slide in
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-13-2005, 05:43 PM
Re: Issues with alternator
We got it but thanks.. Ill keep that in mind if I ever have to do it again
