Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 07-05-2005, 06:33 AM
92x 92x is offline
need help on parts
hello i will be making a 2000 mile trip from ny to tx with a 5000pd trailer. i will be getting the following parts if anyone can help with what will be the best type or size i want to make sure the stuff will be the best for the truck thanx u
1 oil cooler
2tranny cooler
3electric fan pusher
i already have aal and helperspring should i get sway bar for the rear?
things not sure if i should get but if they will be a big help or there def needed i will get thanxs.
1 headers i have a small leak and not sure if it would get worse or how needed they are there in good shape besides the leak very small
2 throttle body
3 chip? not sure if it will be benifissial
4 highflow cat and muffler
5 homemade intake will this work i know it will fit but will it work? throttlebody to coupling to maf to coupling to k/n filter right over the fan not sure if its to short thanxs for all youre advice if u have anything to add that will help please add thanx andrew
Old 07-05-2005, 01:02 PM
chr97 chr97 is offline
Re: need help on parts
If the leak is at the gasket, it is not expensive or hard to replace. I don't think it would be that necessary. The throttle body if it looks in good shape I would just clean it. The only good a cip will really do is speed. The cat and muffler if they have never been replaced, will help with your fuel mileage, they might be getting to the point they will glog. If your intake is still good I probably wouldn't change it. I am not sure about the other stuff.
Old 07-05-2005, 10:28 PM
92x 92x is offline
Re: Re: need help on parts
well thanx u very much not sure what will happen with the headers. if i do headers i will do all if i can get away with not doing headers i will do nothing maybe custommade intake if someone tells me it would work thanx u
Old 07-07-2005, 02:41 AM
92x 92x is offline
does anyone have any suggestions
Old 07-07-2005, 11:01 PM
92x 92x is offline
anyone?
Old 07-09-2005, 01:44 PM
ok I talked it over with my husband, He said if the leak is coming from the collectors (change collector gasket), or if it is coming off the exhaust manifold (lower part of the head on left and right bank of the motor, if leaking Change manifold gaskets). My husband recomends on the tranny cooler and oil cooler to go one size up for what they suggest for the year and size, On his 75 ford he has 2 tranny coolers. Electrical fan pusher if yours is in good condition you don't need to change it, unless you want to go to a bigger one. If you do not already have an anti sway bar deffinately put a sway bar on. My husband is all for the chip he says it will increase horse power, and increase torque depends on the stage of chip you get he said they make 4 for the 92. The cat and muffler he says to have them mandrel bend not pipe bend the pipe, Pipe bending causes kinks. Go from stock to 2 1/2 within the first 3 inchs. make sure it is a 3 baffle cat not 4 baffle cat, come out of cat at 2 1/2 pipe into the muffler, depending on space available 3 inch all the way out. (2 1/2 will create enough back pressure for o2 sensors to sense the exhaust, and will not scavage itself). The intake he says to try them both with the trailer to see witch responds better and keep an eye out for the check engine light. He says that this way you can increase the horse power and torque with keeping your fuel economy down.
Hopefully this helps you out a little more.
Old 07-09-2005, 11:58 PM
92x 92x is offline
well thanx u very much do u know were i could get a chip also i want to add a pusher fan my stock fan works great i just put a new water pump and clutch so its good to go but i wanna give it a little more help not sure what size pusher fan to go with and what brand is good with a reasonable price thanx u
Old 07-10-2005, 02:40 PM
You can order a chip through Summit racing or Jegs online. They also sell the pusher fans. They will have sizes listed, they will also have a customer service number on the website you can call and theycould help with the size for what you want it to do.
Old 07-10-2005, 11:07 PM
92x 92x is offline
thank you
