Old 07-04-2005, 10:53 PM
Sp3c1al ReG's Avatar
Sp3c1al ReG Sp3c1al ReG is offline
Send a message via AIM to Sp3c1al ReG
Rough Shifts
Ive noticed a few times while driving, and especially today sitting in traffic that its really rough and hard shifting into first and sometimes second. Should probably mention im talking about a manual trans. Any reason why it might be so tough? I have to the clutch in as far as i should...just a lil befuddled
Old 07-04-2005, 11:04 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Maybe you need a new one
Old 07-05-2005, 04:42 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Rough Shifts
sounds like something got down in there on the driver side of the shifter, making it hard to get it into alignment, sometimes a peice of trash, or carpeting can do it. other than that it may just be out of adjustment. shouldnt be a hard thing to fix.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-05-2005, 10:29 PM
Re: Rough Shifts
ill take a look at it, i was just hoping it wasn't tranny related
Old 07-07-2005, 12:05 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Rough Shifts
could still be tranny related. do you have an aftermarket shifter? B&M maybe? if so, might not be installed properly. sometimes people leave the little rubber alignment piece out.
if not aftermarket, how does your clutch feel? does it engage when it is close to the floor, or when it is close to the top (the end of its travel)? if it's close to the floor, this could be it, and this can be adjusted.
Maybe a worn ball.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-07-2005, 06:51 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
make sure your hydro clutch is not leaking. I have had them have a slight leak in them and the clutch would not disengauge all the way.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 07-07-2005, 09:47 AM
Re: Re: Rough Shifts
Maybe a worn ball.
my car is bone stock, and my clutch feels fine. Only thing that bothers me a little is, i usually on here it after taking off from my home parking spot, when i shift into 2nd, i hear a werid noise, but it usually doesnt do it...imma take a look today at it. Im a little confused to what u mean engage. If you mean engage to be able to shift gears, then its to the floor, if u mean engage for like taking off, then its closer to the top
Old 07-07-2005, 12:17 PM
Re: Rough Shifts
that's odd. normally the point where you can shift gears is the same as the point where the car starts moving. but anyway... if you can't shift gears till it's completely to the floor, you should have your clutch adjusted so that you can shift with it 50-75% depressed.
Old 07-07-2005, 01:26 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
IK, that is something I need to do on mine, like you said it engages when it's almost to the floor... how do you adjust it???
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 07-07-2005, 01:55 PM
Re: Rough Shifts
don't remember exactly.... had a friend do mine long long time ago (on a Honda). i remember it's relatively easy though. on the cable that attaches to the clutch, there is an adjustment thingy , kinda like the one on the tranny TV cable. don't know where it is on a camaro (I've never had a manual camaro). they all can be adjusted though.
Old 07-07-2005, 01:58 PM
Re: Rough Shifts
yeah, ill take a look at it. My shifter is so weird, some days its fine, some times its being retarded, ill take it apart and look at it
Old 07-08-2005, 06:07 AM
Hypsi87's Avatar
your clutch is hydraulic, it should adjust it's self. However, instant kevin is right, your clutch should disengage before your pedal touches the floor. You might have a leaky slave cylinder or a leaky master cylinder.
Just remember though, just because there is a leak, does not mean that you will see it. Most of the time it is an internal leak between the cylinders.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 07-08-2005, 06:20 AM
goldz28's Avatar
goldz28 goldz28 is offline
Re: Rough Shifts
I was having the same problem with my clutch acouple of months ago. It was the slave cylinder. On my car the slave cylinder is inside the bell housing so they have to pull the tranny just to get to it.
Good luck
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 07-08-2005, 09:32 AM
Earlsfat's Avatar
Cheesesteakoholic
Re: Rough Shifts
Hypsi, are you sure I've got a hydraulic clutch???
Old 07-08-2005, 12:04 PM
Hypsi87's Avatar
no but I am sure that the guy that started the thread does. yours should have a mechanical linkage.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
