Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-04-2005, 07:03 PM
Flambaosting Flambaosting is offline
high boost on 420a motor
is it possible to boost between 15-20 on the 420a aluminum block with fairly built internals? am thinking sleeves, pistons and rods and also maybe valve springs and retainers. can that aluminum block handle the boost even with all the mods?
Old 07-04-2005, 11:06 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: high boost on 420a motor
I don't know about the 420a, but I know my honda friends ran insane amounts of boost when they sleeved their aluminum blocks. I'd say 15-20 is fine with a built motor.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 07-05-2005, 12:19 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
i'd say with the right charged air temp, timing, AFR, cometic head gasket you should have no problem pumping 15-20psi on a built short block.
DSM geek
Old 07-05-2005, 01:02 PM
Re: Re: high boost on 420a motor
do you know which honda motor was sleeved?
Old 07-05-2005, 05:58 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Don't all of them? for the most part they all have the same basic structur
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 07-05-2005, 11:58 PM
sleeved i meant changing the stock sleeves to iron sleeves
Old 07-07-2005, 03:00 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
i'm sure you could run more than that if you do all of that work to it. sleeves, pistons, rods, crank, valves, springs, retainers. you can run all the boost you want then.
95 Talon TSI AWD
97 Eclipse GST
Old 07-07-2005, 05:46 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I personally dont know a lot about how a turbo engine works and all that, but my friend Shawn has a 420a in his Neon and when he gets his new turbo, he said he'll be runnin around 22 psi. Also, one of my other friends with a 420a in a 99 RS was running at 20 psi. Both cars have built engines about like what you were saying.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
