Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-04-2005, 04:41 PM
joross422 joross422 is offline
A/c Questions????
I bought a R134 kit, and there was all ready a new type fitting on the line, So I took it as it has already had it in the system. The compressor was unhooked So I hooked it back up with the green (power?) wire to my left facing the compressor. Tried to fill it and The freon just escapes out of the other port. The compressor will kick on if jumpered and I changed the sensor on the the evaporator just in case. When the compressor is jumped it will stall the motor, and just barely turns over. When I try to turn the compressor by hand I can barely turn it. Thanks, In advance.
Old 07-07-2005, 02:18 AM
2000CAYukon 2000CAYukon is offline
Re: A/c Questions????
Sounds like the compressor is siezed. You will need to replace it along with the accumulator and orifice tube.
//2000CAYukon
