Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-04-2005, 04:40 PM
Rudwoman Rudwoman is offline
2003 Impala-Brakes?
I've read a lot of information in these forums about the rotor problems. Here's the issue... When I step on the brake pedal, it pulsates - a lot! 36,000 miles on the car. I just spent $300 on new front tires and a front and back end alignment - done by a reputable mechanic. Then I spent another $100 on pads and rotors for the front - labor done by my fiance who knows what he's doing. He actually said the rotors and pads didn't really look that bad, but he replaced them anyway. Guess what? The pulsating is still there - maybe worse. I'm running out of money and my fiance is running out of ideas. Any suggestions are greatly appreciated!!! JoAnne...
Old 07-04-2005, 04:56 PM
thermal izod thermal izod is offline
i had a '95 lumina with a similar issue....turned out to be the ball joints....dunno if that's ur fix, but that's what my problem was...
Old 07-04-2005, 09:38 PM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
Re: 2003 Impala-Brakes?
do you have ABS?
They will pulsate when you hit your brakes.
Old 07-04-2005, 10:38 PM
Re: Re: 2003 Impala-Brakes?
Originally Posted by victimizati0n
do you have ABS?
I do have ABS, but this issue just started a few weeks ago. I've had the car since 11/2002. They've never done that before. I've had other cars with ABS and the brake pedal never pulsated. But thanks for the response.
Old 07-05-2005, 09:07 AM
are u getting any kind of feedback through the steering wheel or brake pedals? this is a confusing problem...it's gotta be something in the front suspension if the rotors and pads have been ruled out, but i dunno at this point...
Old 07-05-2005, 09:57 AM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
My impala is doing the same thing. I replaced the brakes, rotors and pads on the front, lower control arms were replaced. The ball joints where too i think...i will let you know. I'm thinking it might be a bent rim......
mike
Old 07-05-2005, 10:11 AM
Heavy pulsating in the actual brake pedal itself when I apply the brakes.
Old 07-05-2005, 10:12 AM
mike
I don't think mine is a bent rim - I would hope the mechanic would have noticed that when he replaced the tires. But I'll keep that in mind. Thanks
Old 07-05-2005, 08:35 PM
i'd say it could be a bent rim....i mean, if ur not getting any feedback in the steering, it's gotta be something misalighned or bent near the wheels....maybe a second opinion? a bent rim can be very easy to miss...
Old 07-11-2005, 03:41 PM
Sinkhole's Avatar
Sinkhole Sinkhole is offline
Okay heres the fix to the problem. My '03 Impala had the same typical rotor issues everyone else is having. Rotor warpage is usually caused by overheating the rotors. I ordered a set of Power Slot rotors, which are designed to disapate heat quicker, and a set of Hawk ceramic pads from Tire Rack, for both the front and the rear. They are a little pricey compared to local parts house Raybestos or Bendix stuff, but I have not had a problem since installing them. One critical point. DO NOT TIGHTEN LUG NUTS WITH AN IMPACT GUN. Hand Torque To Manufacturers Specs.
Old 07-11-2005, 06:52 PM
that's a good call
