turn signal
I have a 98 GM LS. The problem is when I put the turn signal on (left or right) sometimes the dashboard turn signal will not light up and the turn signal tic sound will be faster. Also the front turn signal will not flash and light up. Other times the turn signal will work fine. Any suggestions on the problem on how to fix?
Re: turn signal
multi finction switch
-=-=-DANE-=-=-
id try a new flasher its located in the fuse box its the big round thing the 1992 one is located in the fuse box under driver side dash not sure of 98 though
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs ![]() also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon |
Re: turn signal
the big round flasher has been replaced with electronic flasher units by 98 - they have gone bad but very rarely - the multi function switches in these are a very common problem and the symptoms of some lights not working all the time are tell tail signs on the switch going bad
-=-=-DANE-=-=-
huh was unaware of this thanks for corecting me
