Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-04-2005, 08:22 AM
nymorey nymorey is offline
Send a message via AIM to nymorey
2000 window cable
the cable for my power window broke. I can;t see in the door panel well enought o figure out how it works. Anyone have any information on how to fix this?
Old 07-04-2005, 08:38 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2000 window cable
Actually the window works on a regulator. It is powered by a motor and moves up and down inside the door. This regulator is metal track and in order to get to the regulator you will need to remove the door panel. You will also need to have the proper tool to remove the door panel or you will damage it. Once the panel is off there is a piece of plastic sheet, weather seal, that you need to gently remove. You will be able to see the window regulator once you get this off.
Old 07-04-2005, 08:35 PM
Re: Re: 2000 window cable
I removed the door and the plastic sheet. I see the track (I've got the window being held up by vice grips attached to the track below the window). I see a cable that is attached to the window (regulator?) on the track. It runs over to the motor where it has snapped. I can't see enough inside the door panel to see how it should be routed and how to replace it. It looks like I will have remove the motor to get to the cable, or is it sold as a unit?
I think this is lookinglike a job for the dealer, eh?
Old 07-05-2005, 06:24 PM
Pontiac Guy
Go to a local wrecking yard and purchase one for you car. You will save about 75% on the cost. The motor is not hard to remove and you should be able to replace it fairly easily. The hard part is done, you already have the door panel off.
Old 07-05-2005, 06:33 PM
I'm still not clear about how the cable is routed and how it attaches to the window and the motor
Old 07-08-2005, 11:14 AM
Pontiac Guy
Unfortunately, none of the books I currently have show the routing of the cable. Maybe someone else knows where it actually runs.
Old 07-09-2005, 08:03 PM
Finally took it tothe dealer. Yikes, it was expensive. I guess the window motor and modulator comes as a unit.
