Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-23-2002, 02:12 AM
PhatBastard PhatBastard is offline
Knock sensor - where is it?
Anyone have a diagram of where the knock sensor is located ('95 SE)?
Old 04-23-2002, 09:57 AM
NJMAXSELTD NJMAXSELTD is offline
It's under the intake manifold, sort of twards the right side. It's a small black module held in place by one bolt.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 04-25-2002, 05:57 PM
Found it - changed it...
Found the knock sensor and changed it today. Took about 15 minutes...
Thanks.
Old 04-26-2002, 07:33 AM
Re: Found it - changed it...
Thanks.
15 Minutes? Your good! I've heard a few interesting stories from guys who've changed them.
Did you notice any improvement in performance yet?
Old 04-26-2002, 08:45 AM
Yep, 15 minutes...
Well,I didn't include the 2 days of contemplation on what was the best way to go about it.
But after reading a couple of posts here and on the "Org", I came up with a solution that works - and works fast!
I documented the proceedure on a personal website of mine that I mess around with from time to time. If anyone is interested. Why? Who knows. Just another hobby I guess.
http://www.skippynet.com/maxima/knocksensor.htm
Old 04-26-2002, 08:50 AM
And by the way....
Oh and I haven't noticed any improvement in performance as of yet. From my research, it looks like it takes a few days for any noticeable difference.
I've reset the ECU, so hopefully this will clear up the O2 sensor message as well.
Time will tell...
Old 04-27-2002, 09:49 AM
maxgtr maxgtr is offline
Why did you have to replace your knock sensor, cause my ecu is throwing a knock sensor code also. One more thing. how do you gain performance by replacing the sensor?
project vq30de coming to a theater near you
Old 04-27-2002, 10:36 AM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
LMAO, nice website write-up !!
I loosened the nut a bit different, and was careful of banging my hand when it came loose, because I knew what would happen
You will not gain any "performance". the only thing is your engine will not knock anymore if you use low octane gas.
when you use low octane gasoline the knock sensor retards the timing in order to prevent the "knocking" of your engine in which you might "feel" a decrease in "performance".
so from now on use 93 octane gasoline
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 04-28-2002, 12:37 AM
My ECU was spewing the knock sensor code and a rear o2 sensor code.
Under advisement of NJMAX, I replaced the knock sensor first, in hopes that it would also clear up the o2 sensor message. So far, so good.
The check engine light has not come back on. If it doesn't come back on in the next couple of days, I'll be satisfied that both conditions have been corrected.
As far as better performance, I can't say. I've seen many opinions on this, some saying it will, some saying it won't.
My question is, if the knock sensor is bad, does the ecu still retard the engine? If it does, then maybe you'll see better performance. If not, then nothing should change. Ya think?
My next question is, why does the little bastard cost so much? A plastic doughnut with a metal bottom. Give me a break....
Old 04-28-2002, 12:47 AM
Glad you liked it!
I just started using 92+ octane a couple of weeks a go thanks to information that I read here and on the "ORGY". I have been running the the middle grade (usually about 89) for all of these years because I swear on my granny's grave that the salesman told me to use the middle grade of gas back when I bought my Max new in May of '94, the rat bastard!
Old 04-28-2002, 01:27 PM
mishmosh2000 mishmosh2000 is offline
Damn screw!
PhatBastard, your page is definitely the best thing going out there for KS replacement. Got the tools you suggested but when I went to loosen the screw, the damn thing just would not budge. The car was still kind of hot so maybe when cold, it'll be easier. I also sprayed some liquid wrench on it.
I too would like a definitive answer as to whether timing is retarded (or not) when the KS is bad. I get 0304 code but subjectively, I still feel like my car has good acceleration! We'll see when I change it out...
As for mid-grade: it isn't necessarily a bad thing. The KS is supposed to retard the timing so that no knocking occurs. It is not supposed to damage the KS... Even the manual says that if premium is not availble, "plus" grade will do. You just won't get optimal performance.
Update: With the car cold and the bolt sprayed with liquid wrench, all it took was a good yank and the bolt came loose. Just kept turning the socket until it was out and held the bolt with a magnet antenna. Didn't even have to stick my hand in for the removal portion!
Old 04-28-2002, 08:55 PM
Excellent!!
Glad my web page helped and your idea with the magnet is excellent.
I'll update the web page with your ideas when I return home later this week (I'm working in Atlanta for a few days).
Thanks for the info on the mid grade as well. I don't feel so guilty now!!
I'll try to remember to let you know when I update the web page.
Later.....
Old 04-29-2002, 11:19 AM
MaxRX7's Avatar
Glad you liked it!
NEVER, ever listen to a salesman !!
Whenever you get a new car, read the manual, this is by far the most important thing. It clearly states to use premium gasoline.
BTW, how much did the knock sensor cost you ?
Old 04-29-2002, 02:35 PM
Yeah car salesman suck!
I paid $164 & change for the sensor from Courtesy. I saw some that cost less and some that cost more. Saw a couple of different mfgs. too.
I went wth the middle of the road (cost wise) from a reliable source.
Old 04-29-2002, 06:15 PM
KS testing?
Am wondering if anyone has done the continuity test on their knock sensor as per Haynes Manual. Test: check the resistance of the KS. If it is infinity (no continuity), then they say to replace it. They do say that the KS has a high resistance and recommend an OHM meter with at least 10M Ohm capability.
If you do try to do this, you cannot just measure at the harness because only one of the leads (the signal one) actually goes to the KS. The case of the KS is grounded so you will have to measure with the terminals of the KS that you took out, or use the hot lead of the harness and use the ground of the car.
'93 Accord knocking sound is obvious where it is but don't know what it means deesandvees Accord/TSX/Accord Hybrid 1 09-09-2008 05:13 PM
98 3.3L V6 where is the knock sensor? johnholl Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 01-13-2007 03:55 PM
Where is the knock sensor? mikalcarbine257 SC/SL/SW 2 04-16-2006 06:52 PM
Where do I find the rear knock sensor on a 5.3 2002 Yukon farnorth Tahoe 2 02-10-2005 02:16 PM
wheres my knock sensor crx1125 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-02-2004 03:33 PM
