Old 07-03-2005, 10:44 AM
Ferdi1969 Ferdi1969 is offline
Post replacing Wheel bearing 1998 Chevrolet blazer 2WD
Do I need to replace the whole hub or can i somehow replace only the bearing rings that NAPA sold me. It's quite a cost difference as you all know.
Problem is that when removing the 3 bolts that is holding the hub assembly, the hub assembly doesn't come off. It's like its pressed on the steering knuckle. I have to change it real soon cause the wheel is quite loose on the axle.
Can anyone help with some advice and websites with pictures ??
thanks Ferdi
Old 07-03-2005, 04:05 PM
DINO55's Avatar
DINO55 DINO55 is offline
Re: replacing Wheel bearing 1998 Chevrolet blazer 2WD
I Hope this helps you.......
I am not looking forward to the day when I have to buy these for my 98 2wd........
http://www.automotiveforums.com/vbul...wheel+bearings
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 07-03-2005, 04:30 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
bearings can be replaced separately in a 2wd.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-03-2005, 10:56 PM
Unhappy
Still confused, some threads say I can't replace only the front bearings for my 2WD, other threads say I can!?!?! Tommorrow I will drive to my mechanic and I will post the outcome in a reply thanks
Old 07-03-2005, 11:01 PM
BlazerLT's Avatar
AF -Advisor
4x4 = have to replace the hub.
2x4 = you can replace the bearings themselves.
Old 07-03-2005, 11:04 PM
Re: Re: replacing Wheel bearing 1998 Chevrolet blazer 2WD
OK Thanks
Old 07-03-2005, 11:23 PM
DINO55's Avatar
That's kinda what I thought, that you can replace the 2wd front bearings. Ferdi, I will be looking for your post... Thanks
Dino
Old 07-04-2005, 06:33 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
98+ 2wd bearings are similar to the 4x4 bearings. They CAN'T be replaced seperatly. They are a sealed system. 97 and below are the cheaper simpler ones. (done a couple of these, not as much as a pain as the 4x4 because you're working with a spindle and not a knuckle)
Old 07-04-2005, 01:38 PM
Exclamation Re: Re: Re: replacing Wheel bearing 1998 Chevrolet blazer 2WD
nice discussion, do you agree BlazerLT?
Old 07-04-2005, 01:55 PM
blazee's Avatar
blazee blazee is offline
Problem?
That's what I thought.
I was told that I was wrong is this thread:
http://www.automotiveforums.com/vbul...d.php?t=381979
Now I don't know what to believe, there are two different views and both sides are positive that they are right. I'm still leaning towards them having to be replaced as an assembly. Normally when I'm in doubt, I listen to you or Wolfox, but you guys are on different sides of this one.
Will some one please put an end to this? And let's update all the old threads too, so that it doesn't come up again.
Old 07-04-2005, 04:42 PM
BlazerLT's Avatar
AF -Advisor
From my investigation through the service manuals I have which cover up to 1999 and checking out the part assemblies options on ACDelco.com, it looks like you can find separate bearings if you want for 2wd vehicles there.
Part # S602 outer bearing
Part # S6 inner bearing
The separate parts are there to get so therfore they should be able to be repaired separate on 2WD models.
You can replace the whole hub if you want, but you do have the option to replace only certain bearings if need be.
